Quiet gaming desktop
Discussion in 'Desktop Hardware' started by mattstermh, Aug 5, 2016.
  1. mattstermh
    mattstermh Notebook Evangelist
    I've been out of the desktop world for 10+ years, so forgive my ignorance.
    I only play counter-strike GO and I would like to have a constant 120+fps at max settings on a desktop that doesn't output a tremendously annoying noise. Would I best off building my own (I really don't have time for that these days) or are there specific models/towers I should look for?
    I'm trying to keep it under $900
  2. saturnotaku
    I would go with a Fractal Design case and Noctua fans. The case is well designed and the fans are exceptionally quiet for the amount of air they move.
    deadsmiley likes this.
  3. JAY8387
    JAY8387 Notebook Consultant
    have a look here
    http://www.silentpcreview.com/
    if you can, i would always recommend building your own
    but i you go for pre-built the whole system will come with a warranty
    also id look into water cooling (means you can run fans slower = less noise)
    sorry didn't see you budget ignore the water-cooling
    im gona be difficalt now & ask you questions :p
    1. what else other than CSGO? what settings? what fps?
    2. what else do you intend to use the computer for?
    3. are you ok with used parts?
    4. do you need a copy of windows?
    5. do you need a mouse/keyboard/monitor/ect is this included in budget?
    6. what resolution?
    7. do you want to overclock?
  4. mattstermh
    1. Just CSGO - 120FPS, and I'm not looking for the FPS to drop when in smoke
    2. Basically, just CSGO
    3. Sure
    4. No
    5. No, I have everything else (all peripherals)
    6. Doesn't matter
    7. Not necessarily, if it runs at 120FPS consistently.
  5. JAY8387
    so I assume you have a 1080p monitor?
    also what country are you in? I assume the USA but not sure
    any particular retailer that you would like to avoid?
    do you care about having a pretty pc/ a case with a window?
  6. WaffleBoy
    WaffleBoy Notebook Deity
    Any desktop case with this 900$ is good, what's important is the GPU. A strong GPU will run Cs go quiet.
  7. mattstermh
    I have a 1680x1050 and a 1080p monitor.
    I dont care for the look of the case.
    And yes i am in the USA
  8. houstoned
    houstoned Yoga Pants Connoisseur.
    CS:GO's graphics are pretty dated. is that game even that demanding?
    go grab a used watercooled 980 Ti or something and just build your system around that.
  9. mattstermh
    CSGO isn't super demanding but for High settings at a constant 120FPS, you need some top gear.
  10. TomJGX
    TomJGX I HATE BGA!
    980ti is more than enough.. Even a 1070 should be fine!
  11. killkenny1
    killkenny1 Too weird to live, too rare to die.
    Isn't 1070 more powerful than 980Ti?
    Anyway, even my 970 holds stable 120 FPS (I have it locked in console). Don't remember noticing any drops.
    mattstermh likes this.
