Quiet, cool laptop for mid range gaming under $1,000 ?
Discussion in 'What Notebook Should I Buy?' started by marcv123, Aug 14, 2019.
  1. marcv123
    marcv123 Notebook Enthusiast
    Hi, looking for a quiet laptop to game with. Want to be able to use this while others are watching TV in the same small room, so it must be quiet under load even with fans running. Hoping it wont get too hot either, so I do not need a cooling pad.
    I wont be playing super demanding games. World of Warcraft, Pillars of Eternity 2, Guild Wars 2, etc. Don't care too much about ultra settings or high frame rates. Definitely want a graphics card, but does not have to be newest generation.
    I'm willing to wait a bit for sales around black Friday if that helps. Should be 15" or smaller, not very heavy.
    START COPY
    General Questions
    1) What is your budget? $1,000, with a sale
    a. Ultraportable; 10" - 12" screen
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15"
    a. Like:
    b. Dislike: Anything too flashy or gamery. Want a somewhat grownup looking laptop
    5) Would you consider laptops that are refurbished/redistributed? No
    Light gaming, web
    Mostly keeping it plugged in, or on a couch.
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?) Yes, WoW, Guild Wars, Pillars of Eternity 2
    Don't care much
    On line is OK
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Windows
    Screen Specifics
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    Dont care
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.)
    Build Quality and Design
    Not too flashy, no neon.
    Notebook Components
    15) How much hard drive space do you need?
    Dont care
    Timing, Warranty and Longevity
    16) When are you buying this laptop? Next few months
    17) How long do you expect to use this laptop? 2 years
    18) How long could you afford to do without your laptop if it were to fail? awhile
    19) Would you be willing to pay significantly extra for on-site warranty, or would it be acceptable to you to have to ship the laptop to the vendor for repair with perhaps a week or more outage?
    Ship is fine.
    END COPY
  2. KING19
    KING19 Notebook Deity
  3. NB_Neenja
    NB_Neenja Notebook Consultant
    Oof, this is a tough one. Quiet gaming is considered a feature of higher end laptops, so with a budget under $1,000 options are limited.
    When you're talking fans, noise is measured in decibels or dB. 30-35 dB is considered quiet. 40-45 dB is audible. And 50+ dB is considered loud.
    I was only able to find one laptop that met your requirements: the Lenovo Legion Y730-15ICH. It's a mid-range laptop (i5 CPU, 1050 Ti) and the reviewer found it had an average fan noise of 33 dB under load.
    If you want a more in-depth search, you can actually use Notebookcheck's laptop search that allows you to input both the specs and the dB rating you're looking for.
  4. marcv123
    Thanks for the replies. If I went a bit more expensive, would I be able to find something both quiet and with decent performance?
    Also, what about resellers such as ibuypower, hidevolution, or gentecpc who will do things like repasting, putting in cooling optimizations, etc. Are those worth it?
