Quick question for those who oiled their M11X fan!
Discussion in 'Alienware M11x' started by Fliplm0de, Nov 10, 2013.
  1. Fliplm0de
    Fliplm0de Notebook Enthusiast
    Hey guys looking to oil my m11x fan to see if it gets rid of the grinding noise. And just wanted to know if i was applying it in the right area.
    Is the yellow boxes the correct places? Only asking since the fans I've worked on usually have a small cover you pop off and apply it there, the fan of the m11 looks like 6 small bearings?
    THANKS!
  2. Fliplm0de
    Wow no one?
  3. Dinosaur Brutus
    Dinosaur Brutus Notebook Geek
    The M11x isn't exactly the most disassembly friendly laptop out there, so I'd figure few people have actually taken theirs apart. The other issue is that since the fan is even more difficult to disassemble than the rest of the laptop, I'd wager even fewer people have taken that apart. With this in mind, it'll be difficult to tell you where to oil the fan if people aren't sure, in order to avoid the possibility of advising something that could damage your computer.
  4. trikster
    trikster Notebook Evangelist
    What you have pictured looks to be the mounting points for the stator in the motor portion of the fan. It doesn't rotate and oiling there will do nothing for you except possibly shorting the motor or causing it to run erratically. Usually these fans are on a ballbearing, so the noise you hear is most likely built up dust and dirt that has wormed its way under the plastic fan and is grinding between the fan and the motor mechanism. I would try to use compressed air to blow out the fan as best you can or replace it.
  5. bobthedespot
    bobthedespot Notebook Consultant
    As long as you use the right kind of oil, you don't have to worry about where it goes... just get it on the bearing inside the casing...
  6. Fliplm0de
    Hmm thanks for the response. I am pretty sure the fan is damn clean as I cleaned it pretty good but I guess I can take a look again. As for replacing the fan, it's connected to the heat sink how easy is it to just replace the fan itself ( looks to be attached to some adhesive?) or would one just replace the whole heat sink assembly?
    Thanks for the response, I'd like to be a bit more careful than that lol.But if nothing shows up I guess i'll try it out.
    Heres a video for all to hear the severity of the grinding.
    VIDEO0010.mp4 - YouTube (Might need to turn it up)
  7. Steelfatboy
    Steelfatboy Notebook Guru
  8. Fliplm0de
    Do you know how easy it is to replace the fan? It seems to be some adhesive that keeps it glued down, I don't want to rip that off to find I can't reapply it and stuck with a fan that isn't properly seated.
  9. Steelfatboy
    Sorry, I don't know how easy it is to separate the fan from the heatsink but it should not be too difficult. Hopefully, some others can weigh in. Otherwise, there are complete heatsink and fan assemblies selling too, for not a lot.
  10. clemenzina
    clemenzina Notebook Consultant
    A Dell engineer replaced my R3's fan/heatsink (it's a unit, Dell support kept referring to it as "the heatsink" when I was takling about the fan) due to overheating. It took him quite a long time and looked very involved - more than that I cannot say, I'm not techie enough.
    Here's a guy with the same problem ... and here is the Alienware teardown vid which might help you :)
