Questions Regarding RAM installation
Discussion in 'Sager and Clevo' started by alexpre888, Jan 20, 2017.
  1. alexpre888
    alexpre888 Notebook Consultant
    So I am planning to add additional RAM to my Laptop. I have 1 more slot to add another RAM (Total of 16 GB). But I wanted to ask something before I do this. This will be the first time I ever installed a new RAM on my computer so I ask, is there anything I need to check before I choose the correct RAM for my laptop? Is there anything I need to do before installing a RAM? Does it need to be exactly the same as my current RAM card installed, including brand?
    My Current Laptop's specs is on my signature.
  2. saturnotaku
    For best compatibility and to minimize the chance of something going wrong, you should buy RAM in matching pairs. If you can find an identical module to what you have now, great. If not, 2x8 GB kits aren't very expensive.
  3. alexpre888
    good to know, thx.
  4. Spartan
    Spartan Super Tweaker
    Make sure you take off your socks before touching your ram otherwise the static electricity in your body will fry them the moment you touch them. Happened to me before
  5. Prostar Computer
    @alexpre888 - In other words: Make sure you're grounded. :vbwink:
    Papusan and Spartan like this.
  6. Support.1@XOTIC PC
    Support.1@XOTIC PC Company Representative
    If you want to get matching ram as mentioned, you could use a free program like CPU-Z to see what model is in your computer without having to open it up. Just check the SPD tab in that program for model and manufacturer.
  7. alexpre888
    I learned that the hard way at college :p, Good thing I don't wear socks at home though. And, who uses carpets anyways :p
    Prostar Computer likes this.
  8. alexpre888
    So it seems its from this manufacturer. Having a hard time finding RAM from them. Either that or I simply suck at google. :|
    @pat@XOTICPC btw I got my Laptop today from RMA. My PC is good now. Thx XoticPC <3
  9. Prostar Computer
    Try HWiNFO64 - or look at the sticker on the RAM for the info you need.
    Hyundai merged with Hynix (formerly Lucky Goldstar Semi), so it's likely SKHynix memory you will be looking for.
  10. Meaker@Sager
    Any 2400mhz CL17 ram will work fine with it.
