Questions about G-Sync
Discussion in 'Gaming (Software and Graphics Cards)' started by BrightSmith, Sep 7, 2020.
  1. Kevin
    Kevin Egregious
    It doesn't work like this.
    JRE84, Tyranus07 and hfm like this.
  2. BrightSmith
    BrightSmith Notebook Evangelist
    So the error in my reasoning is that I thought capping fps did the same thing as vsync. Thanks for pointing that out. Will just continue to use G-Sync then...
    yrekabakery likes this.
  3. Tyranus07
    Tyranus07 Notebook Evangelist
    I've noticed that even with G-Sync enabled capping fps might help. Sometimes due to poor optimization in games, for no apparent reason you get a frame rate drop from let's say from 144 to 120 fps, G-Sync will prevent from getting screen tearing and still going with a high frame rate, but that little fps drop will cause a perceptible micro stutter. If in that particular scenario your fps were capped to 120 fps you'll not perceive the micro stutter and you'll have a smoother experience. Of course some games are so badly optimized (like Jedi Fallen Order) that in some occasions I go from 90 fps to 60 fps in one particular location, if I cap to 60 fps in the same particular location the frame rate now drops from 60 to 30 fps, that's just a bug not a hardware bottleneck.
    BrightSmith likes this.
  4. yrekabakery
    yrekabakery Notebook Virtuoso
    Also make sure you enable VSync and limit FPS to 3 frames below the refresh rate, as that is the correct way to setup G-Sync.
    cfe and hfm like this.
  5. hfm
    hfm Notebook Prophet
    I concur. My previous laptop had G-Sync and it was best to set it a frame or so below the panel refresh.
  6. Prototime
    Prototime Notebook Evangelist
    Curious, what benefit does dropping it a frame below the refresh rate have?
  7. yrekabakery
    It’s because you have to enable VSync when using G-Sync as this activates frametime compensation to prevent tearing at the upper and lower bounds of the variable refresh rate window. If you don’t limit FPS to at least 2-3 frames below the refresh rate (1 frame is not enough), you’ll just be using VSync instead of G-Sync, and be hit with the full VSync input lag, since G-Sync only works below the refresh rate.
    Papusan, Prototime and hfm like this.
  8. JRE84
    JRE84 Notebook Deity
    unless your getting more than 144fps there is absolutely no reason to avoid g sync end of story
