Questions about Aorus X7 v6-PC3D (Non 1440 screen)
Discussion in 'Gigabyte and Aorus' started by jjp, Nov 27, 2016.
  1. Jared_T
    Jared_T Notebook Evangelist
    Yeap its quite simple. Just some T6 screws to get past and you're in. Alsp when you repaste, check how the wireless antennas are routed. Mine were directly contacting the bottom of a heatpipe so i changed it a little
    And yea it can go 100hz easy. Got it running BO3 at 100hz atm
    Sent from my ONEPLUS A5000 using Tapatalk
  2. case hart
    case hart Notebook Consultant
    you rock man, thanks for the info. What difference did you see in temps when you repasted?
  3. Jared_T
    I cant really say how big my difference in temps are because i initially bought and used it in Malaysia for a few months before moving to the States to study so the ambient temp difference really doesnt do me any favors since its much colder up here. But i can say roughly a 10 plus celcius drop with an aggressive undervolt. Your results with the indervolt will vary depending on how much voltage you can take away from the CPU. I've been lucky to get mine down to -.165 and squeeze plenty of extra battery time and thermal headroom. I dont OC my CPU though, only the 1070
    Pm me if you want more details! Always glad to help someone out :)
  4. case hart
    gotcha thanks for that! I will likely be ocing the cpu all the timeI couldn't find much info on temps when its oced to 4ghz vs any other cpus. At stock its about 5-10% faster than the 6700hq but thats all I can figure.
  5. Jared_T
    A full OC will def push the cooling system to its limit. I almost managed to overwhelm it doing a loop of Firestrike so i would say a 3.8 is a good level
  6. case hart
    dang I was hoping to keep it at 4ghz whenever I had it docked at home.
  7. Jared_T
    I havent tried out 4Ghz in games. ONly in Firestrike. But that is not indicative of what games will be running at so i would think that you'll be fine...??? Just be wary of the fans. They are uh...pretty vocal
  8. case hart
    I am using it more for video rendering so cpu will be near 100% a lot of the time. No worries you have offered me a ton of info I appreciate it.
  9. Jmanthesin
    Jmanthesin Notebook Enthusiast
    Is it possible to play games with low fan noise with this laptop? EX. I set CPU to 50% Speed at 60c, will it stick?
  10. alawadhi3000
    alawadhi3000 Notebook Consultant
    I think its doable if you set the max CPU clock to something like 2.7GHz and the GPU to 1650MHz@0.8V.
