questions about alienware 15 r3 kindly help?
Discussion in '2015+ Alienware 13 / 15 / 17' started by mohamad.hegazy, Mar 17, 2017.
  1. mohamad.hegazy
    mohamad.hegazy Newbie
    hello
    i wanna order alienware 15r3 but configuration is really makes me confuse
    i will be mainly use it for editing and playing games
    build quality and the metal body what brought me to alienware as im planing to keep it for long time i hope
    so do i go with i7-7700HQ or i7-7820HK
    if i goes with the unlocked version i7-7820HK well the machine handle the overclock heating well or it will be a waste of money, dose the extra speed if over clocked and cache gonna help me regarding rendering,etc ?
    16GB DDR4 at 2667MHz
    256GB PCIe m.2 SSD+1TB 7200RPM HDD
    99W Battery
    1535 Killer wifi
    regarding display also i dont know witch one to pick
    FHD 1080P IPS 60HZ 300nit G-SYNC or FHD 1080P 120HZ TN 400nit G-SYNC Screen
    regarding colors accuracy etc
    what do you really guys recommend as for the past 5 days i'm reading all sort of posts and i still didn't set my mind yet
  2. don_svetlio
    If buying 1070 - 7820HK
    If buying 1060 - save your money and get a 7700HQ
    mohamad.hegazy likes this.
  3. SkidrowSKT
    SkidrowSKT Notebook Deity
    Also:
    If you want a 1070, go for the 120Hz display, as the FHD-60Hz panel is overkill for a 1070.
    Sent from my SM-N900 using Tapatalk
  4. mohamad.hegazy
    yea GPU is GTX 1070
    so its i7-7820HK
    about display i read that 120Hz panels has some problems regarding colors accuracy is that true
    and what do you mean by 60Hz is overkill for 1070?
  5. SkidrowSKT
    The GTX 1070 produces a lot more than 60fps in even the most demanding games that exist to this day. Having a 120Hz panel means games will look extremely smooth beyond 60, and the extra horsepower the 1070 provides won't go to waste.
    When it comes to color accuracy, the 120Hz TN panel is not that bad at all. Ir's not as horrible as the older TN panels used in cheap laptops. It's true, it's worse than an IPS panel but I personally see more benefits for having a calibrated 120Hz panel.
  6. mohamad.hegazy
    120Hz TN+WVA if its calibrated it will be good for video/photo editing despite the IPS panel? as i'm buying your POV , thanks for help
  7. SkidrowSKT
    It really depends on how you see it. The IPS still proves to be superior when it comes to color reproduction and viewing angles. For the folks who do photo editing, the winner is clear. The IPS panel has a superior contrast a d a better color gamut.
    I suggest you look at this video for an in-depth comparison:
    To me, either choice is good, mainly because the 60Hz IPS panel is G-Sync ready for games (it helps with smoothening the game when locked at 59fps). The 120Hz panel is also impressive, even during daily use. Although it does look washed out and too bright at some occasions, Windows is snappy as ****.
    don_svetlio likes this.
  8. don_svetlio
    If you're doing any kind of colour-sensitive work - IPS is the bare minimum, hell, OLED Alienware 13 is even better. TN is just not well suited towards that as the technology is simply not good enough.
  9. judal57
    judal57 Notebook Deity
    i can say you this..... if you have the money, go with the best you can buy, you will never feel bad. if i was you, i will check a look for the 17 r4 and look a discount for gtx 1080 and 7820hk .... is not going to be cheap, but having the best of the best is am incomparable feeling. Alienware right now fixed all the problems on heatsink. I know the 3 screw design is not the best, but the heatsink is really good designed and make a good job
  10. Drkknightfan
    Drkknightfan Notebook Guru
    According to Dell the new 120hz panel is now supposed to be IPS........ but there is some confusion if this is true or not. When I tried to order mine at the config screen it states IPS panel, but in the order status screen it would change to a TN panel description. I ended up cancelling and went with the 13 OLED.
