Question regarding gtx 1070(mxm)
Discussion in 'Sager and Clevo' started by j3rwin, Oct 9, 2018.
  1. j3rwin
    j3rwin Notebook Enthusiast
    I'm planning to get a Clevo p750tm1-g with gtx1070(actually placed an order today from a local reseller ). When I asked about the graphics card he said that it comes directly from Nvidia. I saw many posts about MSI cards and some(negative) about gecube but nothing about the cards directly from Nvidia. So I have a few questions,
    1, Is this similar to the reference cards in desktop?
    2, How do they fare(performances, temps) when compared to other cards(say MSI)?
    Even if the info you have doesn't answer these questions any misc details are welcome :)
    Edit: It's a desktop grade card, not the MAX-Q version
  2. yrekabakery
    yrekabakery Notebook Deity
    1. Performance wise yes, specs wise no. The mobile GTX 1070 has a lower power limit (115W/125W instead of 150W) which causes it to boost lower, but performance is on-par with the stock desktop Founder's Edition because the mobile version has an additional SM (128 CUDA cores).
    2. The Clevo card should be slightly faster since the current generation is 125W, while the MSI card is 115W. Temps depends on cooling and will vary from system to system.
  3. j3rwin
    This is for the MAX-Q version right?
    I was specifically told that the card they sell is not the MAX-Q version. Does this change anything(WRT to the points you mentioned above)?
  4. yrekabakery
    All laptop versions of the 1070 have 2048 CUDA cores, Max-Q or not. The desktop 1070 has 1920 CUDA cores. Max-Q variants have a lower power limit (80W/90W), resulting in lower boost clocks and performance.
    j3rwin likes this.
  5. j3rwin
    Thanks for the info :)
  6. bennyg
    bennyg Notebook Virtuoso
    The gecube/msi/undisclosed maxq thing only applies to aftermarket cards (upgrades) not those that come already in it when you buy a complete unit.
    j3rwin likes this.
  7. Meaker@Sager
    The VRM on the Clevo 1070 has had no issues :)
    j3rwin likes this.
