Question: Nvidia GT550m vs. Radeon HD 6770m
Discussion in 'Gaming (Software and Graphics Cards)' started by Wolfborne, Apr 20, 2011.
  1. Wolfborne
    Wolfborne Notebook Guru
    The only game I play is Rift (like WoW but with better graphics). Settings would be customized between High and Ultra. I was wondering which of these 2 cards would offer the best performance in a MMORPG type of game.
    Dell XPS 17
    *2nd gen. i5-2520M (2.5GHz) 3MB L3 cache
    JBL and Creative SB audio
    Nvidia GeForce GT550m 1GB DDR3 with Optimus GPU
    -1480 MHz, 128 bit, 28.8 GB/s
    vs.
    HP dv7t Quad
    *2nd gen. i7-2630QM (2.0GHz) 6MB L3 cache
    Beats audio
    Radeon HD 6770m 1GB DDR5 GPU
    -1600 MHz, 128 bit, 51.2 GB/s
    *for this game and many other MMORPGs the i5 systems run slightly better b/c these games don't really benefit from a quad core (yet). The i5 also runs cooler than an i7.
    So I guess it boils down to 1G DDR3 vs. 1G DDR5 in this type of game. The resolution would be set to 1600x900 for better fps. Would you even really notice a big difference between these 2 cards in a "20 man raid with spell effects flying all over the dungeon"?
  2. Botsu
    Botsu Notebook Evangelist
    Even if your question is about the GPU I think the 2nd system would perform better in MMOs thanks to the quad-core CPU. Anyway the 6770M is better than the 550M. It's approximately on par with the 192bits version of the GT 555M which is clearly more powerful than its little sister.
  3. dn00
    dn00 Notebook Consultant
    The 6770m is in a different league.
  4. Deks
    Deks Notebook Virtuoso
    Agreed.
    The quad system with the 6770 would effectively outperform the first one by a good margin (especially at the resolution you mentioned).
  5. Yiddo
    Yiddo Believe, Achieve, Receive
    28.8 GB/s from the 550M gosh thats low :eek:
    Definetely the 6770 without doubt it would outperform the 555M and the second system would generally handle games better the Sandy Bridge is more than powerful enough even with 500mhz less.
  6. Karamazovmm
    Karamazovmm Overthinking? Always!
    bandwidth = memory type
  7. Yiddo
    Oh yes I know that :) but that still does not make it any better my 8700M GT had 25.6GB/s at 128bit 3 years ago with the same memory it could have done better having a 192 bit bus.
    The faster memory is always the better option but still such a shame to see cards with a stupid amount of Vram being wasted the 445/555m with 3GB's worth is the same marketing scheme.
  8. laptopfan88
    laptopfan88 Notebook Consultant
    Have you looked for gaming benchmarks using GPUs similar to the 550M and the 6670M? Despite the memory bandwidth issues, maybe Rift is optimized better for Nvidia. I'd lean towards the 550M just because Nvidia runs this game better. The 57GTX 460 is noticeably faster than the 6870 for medium and high quality. I don't think the memory bandwidth with what 6770 and 550M are capable is going to make that big of difference.
    It is worth noting that on high setting, the 6870 surpasses the 460. But with your setup, I don't think you'll be playing on high though. The 6770M and 550M are like half the performance of a desktop 460 and 6870.
  9. Yiddo
    Even excellent optimisation would not affect the performance as much as double the memory speed and bandwidth. GDDR3 to GDDR5 and double the bandwidth will make a huge difference. If you could get the 550M GDDR5 version that would be a different story.
    The issues ATI faced with RIFT are now fixed with the recent driver release im getting 15-20 more FPS now with my 5870m with the same settings.
    550M
    6770M
    No gaming benches yet but vantage shows a 2000 points difference and 3dMark11 benches 500-700 points.
  10. Deks
    The 6770M with DDR5 will perform visibly better than 555M on 1600x900 resolution exactly because of the higher memory bandwidth (which offers about 35% improvement over the DDR3, if not more).
