Quck Restore system restore
Discussion in 'Dell' started by Th3xTruth, Jan 29, 2006.
  1. Th3xTruth
    Th3xTruth Notebook Enthusiast
    my dell is all messed up i have dell 6000
    i want to do a restore of the full system like and get it to the date i first bought it ..is this possible or what is the best thing i can do...
    besides..the dell one they give me which is poor..
  2. leeer73
    leeer73 Notebook Geek
    I just did this on my 9300. Reboot your pc, at the "dell" screen, when the system first starts to boot up, hit Ctrl+f11 a few times. That will send you to a page that allows you to restore to the factory specs. Waring!! You will lose all of your crap!! and this installs the dell system the way it was when you originally received it including all of the bloatware! Good luck!
  3. bmwrob
    bmwrob Notebook Virtuoso
    Just a suggestion - before restoring to the original state, you might want to read the following, into which went quite a lot of effort:
    http://forum.notebookreview.com/showthread.php?t=23363
  4. JonNuttNTL
    JonNuttNTL Notebook Enthusiast
  5. Th3xTruth
    im tryin to do this but im gettin nothing..hit at the same time or hold it ..or what...
  6. Amber
    Amber Notebook Prophet NBR Reviewer
    at the dell screen, you hit them at the same time. If you've reformatted or messed with the partitions in any way, the restore partition will not work.
    SG
  7. Th3xTruth
    **** ive had to mess with it before..cuz it was messed up ..so now what am i left to do SG...:(
  8. Amber
    you'll have to do a clean install using the XP disk. If you don't have the XP disk from dell, you'll need to call them and request it.
  9. Th3xTruth
    no no i do...
    so then do what they said up there and use that link for reinstallin XP and i should have it like new again..
  10. Amber
    yep. Just follow the guide and it should guide you through. If you don't clean installs before, then it is the same process. It is just the driver process that most users have problems with.
    Might as well delete the restore partition while you are at it, and gain the space back.
