Quadro P5000 with Clevo P150SM-A (LVDS)
Discussion in 'Sager and Clevo' started by Hardcorecustom, Mar 1, 2018.
  1. Meaker@Sager
    See my post 3 and my diagram. In this machine the dedicated card does not do any display output work.
  2. oljo01
    oljo01 Notebook Enthusiast
    I guess its the same for mine, so it should work!
  3. symy17
    symy17 Notebook Enthusiast
    So to upgrade gtx 1060 from m290x, doenst matter if my display is eDP or lvds? Just plug and play, reapply thermal path, clean and modded drivers and BIOS?
    Enviado do meu MI 8 através do Tapatalk
  4. Meaker@Sager
    Stop and think for a second. Why would the dedicated GPU care what is plugged into the IGP? It has no vision on that connection.
    Mostly with these machines you just have to be careful of small mods needed for the heatsink to fit the new card. VRM contact is very important.
    symy17 likes this.
  5. oljo01
    What card was on the machine before the p5000?. My gtx 780m looks very like the p5000. But sure i need to move the coolingpads
  6. Meaker@Sager
    The p5000m is related to the 1070. Use a overlay tool to compare, do long as they are played out the same thermal pad adjustments can deal with small height differences.
  7. oljo01
    What card was in the p150sm-a before upgrading?
  8. Meaker@Sager
    It could be a variety of cards.
  9. jaybee83
    jaybee83 Biotech-Doc
    iirc it was around the 700M gpu era.
    Sent from my Xiaomi Mi Max 2 (Oxygen) using Tapatalk
  10. oljo01
    Thanks, then it def should work and with the same fan the p5000 does not look anything like 1070, its very like 1060 and gtx 780m .
