Q35 Bluetooth tray...
Discussion in 'Samsung' started by slumbermann, Jul 7, 2007.
  1. slumbermann
    slumbermann Notebook Evangelist
    Its been a while since i last really read the samsung...
    so i would just want to share... there was an issue regarding this before...
    that in the vista setup of the Q35 the bluetooth button is not there in the task bar...
    but it is on the autostart programme folder... when you click START >>PROGRAM>>AUTOSTART>>BT TRAY...
    so no need any extra tool for that... :) thats all.... i dont really know where to write this.... so have fun... :)
  2. John Ratsey
    Thanks. The problem is not that the icon is missing, but the Vista version lacks the start / top option which is present in the XP version (see the attached).
    John
  3. slumbermann
    I think thats really similar with what i have...
    when i click on the BT Tray.. the try will be shown in the taskbar...
    n have some options similar to what you have there...
    there have more options for the bluetooth try icons tho...
    see attachment... i attach the Menu Program, n the options on the taskbar icons
