Prolonging Alienware Laptop Battery Life
Discussion in 'Alienware' started by Alien FlyBoy, Jan 4, 2010.
  1. Zlog
    Zlog Notebook Deity
    your battery is going to degrade in 2-3 years whether you charge it or not. Taking it out, not charging it, etc. really doesn't make any measurable difference.
  2. Serephucus
    Serephucus Notebook Deity
    It doesn't matter. The people that suggest a rundown an full charge are taking what you used to have to go and do with phones a few years back and applying it to laptops, thinking they're the same battery. They're not.
    It's actually slightly worse to run down a laptop battery completely, but even that doesn't make a lot of difference. You can be constantly charging your battery, or you can leave it in a freezer and never touch it - it'll wear down pretty much the same.
  3. Paddon
    Paddon Notebook Evangelist
    Do we know if the M14x has a removable battery ?
    so you can do a quick swap
  4. Killer Juice
    Killer Juice Notebook Consultant
    I think its like the M11x... you can't swap the battery unless you unscrew the bottom
  5. Serephucus
    Yeah, it's under the bottom panel of the chassis. It's not removable, but at least it's replaceable.
  6. M18x
    M18x Notebook Guru
    this.
    but I guess the more you use the battery (unplugged laptop) the sooner it dies :D
  7. azizhp
    azizhp Notebook Geek
  8. Hengst2404
    Hengst2404 Notebook Geek
    With my m11x, I used the option in my bios that said don't charge while plugged in. This worked, although I had to re-enter it every time I restarted my laptop
  9. chris3145
    chris3145 Notebook Consultant
    Lithium ion batteries are usually rated to last for a certain number of charge cycles they last. On my Toshiba Satellite I used to take the battery out and use the computer plugged in with no battery (to cut down on charge cycles) when I knew I wouldn't have to take it anywhere for an extended period.
    It had pretty miserable battery life starting at day 1, so I don't know if taking the battery out helped it last longer or not.
  10. TostitoBandito
    TostitoBandito Notebook Evangelist
    QFT. Don't do this. Also, don't believe everything you read on the interwebs.
