Project Plex Expansion
Discussion in 'Desktop Hardware' started by custom90gt, Mar 15, 2020.
  1. custom90gt
    So I've had my Plex/home server up and running for a while now and I've been pretty happy with it. Outside of being reliant on wireless (can't figure out a way to run ethernet to my TVs without a ton of work), I really haven't had any issues with it. Having said that, I'm not a huge subscriber to the if it ain't broke don't fix it thought, I love to tinker. Initially I started out with the smallest case I could go with and still having enough storage. My next case was a Fractal Define R5 which held 8 3.5" drives and thanks to a 2x5.25 to 2.5 bay it also held 8 2.5" drives. So out with the old:
    Well I'm finally hitting the point where I'm going to start needing more hard drives so I figured it would be fun to upgrade to something with some future proofing. Enter the Supermicro 846 4U 24 bay case:
    I would love to upgrade my hardware with something like a 3900x and 2080ti but I may have to wait a little bit on that. And yes, plex can use the GPU, just have to mod the drivers to remove the 2 stream limit. I was fortunate that my scythe mugen 5 fits in this 4U case! Great cooler for a good price:
    I wanted to do the test fit first. My next phase will be wire management and sleeving the power distribution cables. I forgot how much I dislike sleeving stuff, my molex tool broke 1/4 of the way through and using a sim tool was a pain. This phase will be on hold for a while. I also had to add a Corsair Commander Pro to control the fan speeds. This thing was super loud at full blast.
    Adding the drives:
    Specs:
    Case: Supermicro 846
    Backplane: BPN-SAS2-846EL1
    Mobo: Asrock x470 taichi
    CPU: AMD 2700x
    RAM: ADATA 32GB (4x8GB) right now but I ordered some Trident Z Neo 3600mhz for cheap.
    GPU: EVGA RTX 2070 Black
    Power Supplies: 2x Supermicro PWS-920P-SQ 920W Platinum (much quieter than the stock power supplies)
    Fans: stock 80mm San Ace fans in the rear, 3x Noctua NF-F12 iPPC 3000 PWM that I need to create a better mount for
    Drives: 1TB SX8200 NVMe for OS, 8x8TB WD/Hitachi shucked drives, 2x6TB Hitachi SAS, 2x400GB SLC drives for cache/journal drives, a couple 256-512GB SSDs for caching/temp drives.
    SAS controller: LSI 9400-16i
    I'm still running storage spaces in Windows 10 on it, one parity setup and one simple expanded as a backup (I also have a couple of 10TB external drives as backups of the backups). I would love to do a ZFS setup, but I like running windows natively as I also use it as a Steam Stream machine:
  2. custom90gt
    Did a little work to the server Saturday, was able to sleeve the cables and install new ram. The cables are far from perfect, but at least they look a little better. I also made a fan wall out of some angled wood I had around the house, again far from perfect but it works.
    katalin_2003 likes this.
  3. custom90gt
    Figure I'd update this even though it's been almost a month since I've done the work, lol.
    Swapped out the X470 Asrock Taichi and 2700x for a X570 Gigabyte Aorus Pro Wifi and 3700x:
    Also added a couple 10TB drives:
    I redid the setup and now I have a dual parity drive with a hot swap (9x10TB drives) for the main file store and a parity backup with the 8TB drives. I contemplated going with unraid or something that would be better than storage spaces, but I am stubborn. I think this is how the server will be for a while. I will probably throw my 3900x in there when the 4 series comes out, but then again nothing really touches the 3700x transcode wise right now (thanks to GPU transcoding).
