Processor Difference
Discussion in 'Hardware Components and Aftermarket Upgrades' started by rajuj13, Aug 10, 2011.
  1. rajuj13
    rajuj13 Notebook Consultant
    What is the difference between:
    Intel Core i5/i7 Mobile Processor
    and
    Intel 2nd generation Core i5/i7 Mobile Processor
    Thanks,
    -Raju
  2. Dufus
    Dufus .
  3. Pitabred
    Pitabred Linux geek con rat flail!
    Basically, 2nd gen is faster and better on battery. Get it unless it's obscenely more expensive than the 1st gen.
  4. rajuj13
    Ok. Then whats the difference between Nehalem based chip and Sandy Bridge based chip? Please explain in detail please.
  5. Lithus
    Lithus NBR Janitor
  6. Dufus
    Dufus .
    rajuj13, Pitabred has given a simple explanation, generally newer architecture is better. If you want detailed explanations then follow the links. Processor manuals can be downloaded from the links.
  7. rajuj13
    Ok fine thanks.
  8. rajuj13
    Yes or No answer. Is there a big difference between regular core i7 and Extreme other than the cost?
  9. Star Forge
    Star Forge Quaggan's Creed Redux!
    Extreme Edition has unlocked multipliers for overclocking on top of a higher TDP power threshold and higher multiple clock frequency. It is only useful if you are an enthusiast (overclocking fanatic) or a CPU powerhouse user. Otherwise, it is not worth the investment.
  10. Patrck_744
    Patrck_744 Burgers!
    What kind of job are you gonna give to these processors?
