Problems with G73JH and blue screen error
Discussion in 'ASUS Gaming Notebook Forum' started by pandasouljah, Apr 6, 2016.
  1. pandasouljah
    pandasouljah Newbie
    Hey guys,
    I recently updated to Windows 10 but keep getting the below errors. I tried reinstalling Windows, drivers etc but when I restart the laptop it does it nearly every time. Also freezes intermittently. Should I downgrade back to Windows 7 or is there a fix that I haven't tried. Thanks in advance!
    Sent from my Nexus 6P using Tapatalk
  2. C4RN1
    C4RN1 Notebook Consultant
    Are you running windows 10 64 bit?
  3. pandasouljah
    pandasouljah Newbie
    Yes
  4. C4RN1
    You can try to use the recovery disk I made. I got my hands on MDOP from technet. MDOP lets you customize deployment and recovery options. The recovery is based on MSDART which is what you normally see when the computer tries an auto repair.
    I would normally download something like this but I had to make it due to the fact it was never released.... so here you go.
    Download this iso
    http://pc.cd/e2uctalK
    Make a bootable flash drive with rufus
    http://rufus.akeo.ie/
    Boot to the flash drive, press any key, and select the default option.
    You can try to roll the computer back using system restore, you can also try to repair the operating system.
    Once I get home from work I will update with better instructions, in the mean time try different options.
    Good luck
  5. mufferer18
    mufferer18 Notebook Consultant
    Downgrade. This laptop as mine isn't meant to work in Win10, don't have drivers (this from win7 will install, but will provide you BSoDs, and other problems), I know because even my desktop with support of Win10 have problems with proper performance in certain programs and games, so it's still not developed os.
  6. pato
    pato Notebook Evangelist
    Disable the LAN adapter in Bios and it should work.
  7. pandasouljah
    pandasouljah Newbie
    I dropped back to win7 and all problems have gone. Thanks heaps for the advice guys, much appreciated!
  8. cdoublejj
    cdoublejj Notebook Deity
    10 can NOT be upgraded from 7, it also needs to be installed like this,
    I have to install to 10 year old 2006 mac book pro with 7 drivers and only 2gb of ram and it SCREAMS with an SSD for an 10 year old laptop.
    I'll give it a try on my G73JH. There are tons and tons of hardware reasons the G73JH BSODS.
  9. pato
    My G73Jh runs absolutely smooth, but the lan port needs to be disabled in bios.
  10. cdoublejj
    win 10 or win 7?
