Problems with creating an ISO DVD disc
Discussion in 'Windows OS and Software' started by kingp1ng, Nov 30, 2011.
  1. kingp1ng
    kingp1ng Notebook Evangelist
    So I created a Linux Mint ISO disc by burning the ISO using Power2Go. When I insert the disc, reboot my PC, click ESC to enter the boot menu, and click on "boot from internal disc drive" the disc never runs the ISO! It just goes on to booting Windows 7 like normal. I've been researching this but I can't find a solution!
    Can anyone help me?
    I bought a stack of new 4.7 GB DVD's.
    Burned the ISO on the DVD. (I didn't copy)
    Booted it in the boot menu.
    Didn't work.
    Is the ISO icon supposed to have an picture? My ISO icon is a blank piece of paper. Should I try another program such as Nero or ImgBurn?
  2. lee_what2004
    lee_what2004 Wee...
  3. Patrck_744
    Patrck_744 Burgers!
    Make sure you always verify if the burned image has no errors. It doesn't boot because there was an error when it was burned into the disc.
    PRO TIP: Use the slowest burning speed to avoid errors.
  4. newsposter
    newsposter Notebook Virtuoso
    "boot from internal disc drive" (your words) might be the wrong choice.
    Might be better to boot from dvd drive, where your ISO is.
  5. kingp1ng
    Crap, linuxliveusb doesn't work either!!!
    In windows 7, the .ISO files don't have pictures. They are just "blank pieces of paper". However, I think there is supposed to be a picture! Is there something wrong??
  6. newsposter
    which device are you trying to boot from, your internal hard drive or the cd/dvd optical drive?
