Problems with AMD FirePro M6100 in W860CU
Discussion in 'Sager and Clevo' started by razor0601, May 9, 2019.
  1. razor0601
    razor0601 Notebook Consultant
    Hi, I have a Problem with my W860CU. I upgraded it to a FirePro M6100, shown in Win10 as HD 8950. It works fine, so I decided to flash an Oc VBios from here:
    http://forum.notebookreview.com/threads/amd-dell-m6100-vbios-mod-1150-1725.828087/
    But it seems to be a bit to much for the card. So everytime it want to Go in Windows the Screen says there is a Problem....
    I flashed the VBios with Atiwinflash because in Dos the card wasn‘t recognized. So my problem is how can I flash the old VBios without Atiwinflash? Any solutions?
  2. Meaker@Sager
    You could try booting in safe mode. From there if you cant flash uninstall the drivers (remove files too) and dont let it download any (can go offline to do this)
  3. t456
    Try using pcie.exe before running atiflash in dos:
    PCIE.7z
    Failing that; a programmer always works.
  4. razor0601
    Thanks at Meaker@Sager. In Safemode and uninstalling Driver I was able to flash the original VBios.
    t456 likes this.
  5. Meaker@Sager
    Excellent :)
