Problems following M18xR2 GPU upgrade from GTX675 to GTX980m
Discussion in 'Alienware 18 and M18x' started by I_AM_MUSTANG, Sep 24, 2019.
  1. I_AM_MUSTANG
    I_AM_MUSTANG Notebook Enthusiast
    I didn't use DDU but I did reinstall the GPU driver and checked the box that made sure it was a clean fresh installation.
  2. senso
    senso Notebook Deity
    Try again from scratch with DDU, and run something like HWInfo so you can see power usage, temps, and clocks, post a screenshot of the HWInfo sensors tab after running the Firestrike bench.
    M18x-oldie likes this.
  3. I_AM_MUSTANG
    Ok, should I be ticking the box that says driver folders even though it says not recommended?[​IMG]
  4. M18x-oldie
    Usually the preset should be enough, but you can tick all 4 boxes belonging to nVidia, DDU should be run in Windows Safe Mode.
  5. I_AM_MUSTANG
    OK, so I have uninstalled using DDU. Then I went to the NVIDIA driver webpage and chose the driver for the 980m which came up as 436.30 and the installation is failing. I then tried to install GeForce experience which installed fine but when GeForce installs the graphic driver from within the software it is version 388.13 which is from back in 2017 and it says that is the latest up to date driver. Now the laptop feels really slow and unresponsive at times.
  6. Maxware79
    Maxware79 Notebook Evangelist
    I'd try disabling driver signature if you haven't already. Just in case.
  7. I_AM_MUSTANG
    Just tried that and got this error:
  8. Maxware79
    Strange. I'm guessing that a modded driver inf combined with disabling the signature will work.
  9. Maxware79
    Just on this one, doing a 'clean installation' doesn't remove the old driver. It just resets any Nvidia settings you've changed from default. DDU is needed for this.
  10. I_AM_MUSTANG
    I did use DDU in the end and it still didn’t work.
