Problem with PC
Discussion in 'Off Topic' started by queshy, Sep 6, 2005.
  1. queshy
    queshy Notebook Deity NBR Reviewer
    Hello,
    I recently formatted my computer. I Want to install SP2. It starts installing ( I told it to via the little reminder that pops up). Maybe around 2 min later, right at the beginning of the installation, my computer restarts! Anyone know of the problem? How do I get this installed? I've tried safe mode but the internet doesn't work in safe mode...
  2. nickspohn
    nickspohn Notebook Virtuoso NBR Reviewer
    Maybe just let it see what it does on its own. I had no clue when installing mine what was going on because it took all night. On that night the space shuttle was coming in and it was postponed so i woke up every couple hours to check on it. But maybe just see what it does on its own. :) :) :)
  3. coriolis
    coriolis Notebook Nobel Laureate
    Hmmmm....that doesn't seem right.
    You may of gotten a corrupted install of WinXP...
  4. queshy
    What do you mean see what it does on its own? It restarts! Once it starts installing, it installs for a minute or two MAX and then just restarts!
    What do I do? Thanks
  5. nickspohn
    Will it continue installing? Otherwise?
  6. nickspohn
    Ok, try this, this should work,
    right click my computer
    properties,
    advanced tab,
    settings button (startup and recovery)
    uncheck automatic restart
    now you will get an error message after it does that again
  7. coriolis
    I think queshy means that his computer restarts by itself, just like that without warning.
    I'm still thinking its a software problem, did you reinstall WinXP?
  8. queshy
    Yes, I did.
    I tried doing that uncheck automatic restart thingy, I got a blue screen ,forgot what it said...something about "begin physical memory dump"...didnt catch the whole thing, should I try doing it again and write down an erro message? BTW, thanks for all your help.
    And yes Corolis, there is no warning.
  9. nickspohn
    Yeah, try everything again. Hope it works! :)
  10. coriolis
    I doubt its hardware failure....
    It's not the 700m is it?
