Problem with m18x crossfire
Discussion in 'Alienware 18 and M18x' started by Proplayeroty, Mar 18, 2013.
  1. Proplayeroty
    Proplayeroty Notebook Consultant
    Hi, several days ago i disabled one of the gpus in my m18x so i can use it with a 240w charger. Today, im unable to enable the second gpu again, it dosnt appear in the system specs, neither is recognized by the bios. I tried to reinstall drivers, but it didn't worked. Do you have any idea?
    (now im with the 330w charger)
  2. Mr. Fox
    Is the 330W AC adapter correctly identified in the BIOS when connected?
    - Try doing a power drain.
    - If that does not work, try clearing the CMOS.
  3. TBoneSan
    TBoneSan Laptop Fiend
    How exactly did you disable the GPU ?
  4. Proplayeroty
    I disabled it on windows, how i do the power drain, and clear the cmos?
  5. Mr. Fox
    Power Drain:
    • Remove system battery
    • Disconnect AC adapter
    • Hold power button down 30 seconds
    • Connect AC adapter
    • Load Windows
    • Install system battery
    Clear CMOS (Non-Haswell Systems):
    • Remove bottom cover
    • Hold down power button for 30 seconds
    • Ground yourself to the motherboard by touching a screw on the chassis
    • Disconnect wire from coin cell battery
    • Touch screwdriver tip lightly against pins the wire connects to for 1 or 2 seconds
    • Reconnect coin cell battery wire
    • Connect AC adapter and power up
    • Press F2 to enter BIOS
    • Set date/time and any of your customized settings
    • Press F10 to save and exit
    • Load Windows
    Note: your system may start beeping after clearing the CMOS. Don't panic. Hold down the power button to shut it off. Turn it on again, and it should restart and clear itself by resetting BIOS defaults. If your OS was installed incorrectly with the BIOS set to AHCI instead of RAID, you may need to manually set that back to AHCI in the BIOS for Windows to load. If you have a Haswell machine, see the link at the end of this post because this method won't help you.
    Clear CMOS - Alternate Method:
    • Hold down FN key and power button simultaneously
    • While they are still depressed, re-connect the AC adapter
      (This has never worked for me, but some folks swear it works for them.)
    **Alienware 17 (Ranger) /18 (Viking) Owners** - How to 'Un-Brick' Your Mobo
  6. Proplayeroty
    Your last post appear blank to me
  7. Mr. Fox
    That's because I was not done with it yet. Read it again. ;)
    I hope that works for you. Please post the results.
  8. Proplayeroty
    Well, i tried both, but the issue remained, so i took both cards out and put them back, and now they are working.
  9. Alienware-L_Porras
    I'm glad you got that sorted out so easily, I was gonna ask you to do that haha. Maybe it just needed a reseat to get back to work :p
