problem with kotkey plus driver
Discussion in 'Panasonic' started by domlaco, Jan 17, 2010.
  1. domlaco
    domlaco Notebook Enthusiast
    Hi there,
    i have a CF-18KDHZAVM ( Centrino 1,2 ghz, Digitizer, with Xp tablet pc), and i can't use the front button, for the rotation , keybord,etc... in fact, i know that i have to install the hotkey plus driver, because it is not it the device list, but there is no unknow device, so i don't know how to install this driver!
    someone could help me??
    thanks!
    Dominique
  2. Alex
    Alex Super Moderator
  3. domlaco
    Thanks for your reply,
    i tried to install the hotkey plus driver, but it doesn't work...in fact the only driver accepted by this unknow driver is the meitbn driver ( tablet button), know, i have no unknow driver in the folder device, but it doens't work anymore!
  4. Alex
    You might have to start from scratch
    If you read the posts in the thread that I linked you will see that these cf-18's are a pain to load
    Alex
  5. capt.dogfish
    capt.dogfish The Curmudgeon
    What Alex is trying to say, as gently as possible, is that you may need to go back to the very beginning and start over. If you don't put the drivers in in the correct order you loose the option to install them. Some of us learned this the hard way!
    CAP
  6. domlaco
    hi,
    thanks to all for your help, i'll try just now, to réinstall the system, and i'll install the driver in the correct order...just a précision: my cf-18 is a digitizer screen, and i'm trying to install xp pro ( not tablet pc), the problem is that the digitizer pen doesn't work, and in the général panel ( proprieties), it is indicated "win xp pro", and not tablet 2005...
    thanks, with my appologies for my so bad english.
  7. Alex
  8. domlaco
    Hi there,
    thanks for the digitizer pen driver, it's working :)
    so...i installed all the driver in the correct order : wifi, OS INF , video, sound, modem...and the famous hotkey plus driver...it doesn't work! there is 2 unknow driver, the first is for hotkey driver ( it is ok), and the second is logicaly for hotkey plus driver, but is not recognized...the only driver accepted is meitbnt ( it is the panasonic button tablet), but no way, it doens't work with this file... i have 3 cf-18 ( all the same models), and it is the same problem for each one, so i realy think that it is a driver problem, not a hardware one...
    i try to chat with a panasonic technician, but there is nobody actualy...thanks!
  9. domlaco
    i just chat with a panasonic technician...he told me that the problem was because i don't have XP tablet pc... but i was sure that it is possible to use this machine with Win xp pro?
