Problem with Clevo (P870DM-G) BIOS
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Grimm6Jack, Sep 10, 2017.
  1. Grimm6Jack
    Grimm6Jack Notebook Enthusiast
    Hi guys, I don't know if this is the right topic to post this thread in since this is more of a "Help thread" than a discussion one, if not, then a mod or admin can please change the thread to it's right spot.
    My problem is this:
    -I have a drive with an operating system installed and for some reason it never boots up, it always asks me to insert a bootable device, and when I go to boot options, neither of the drives (be it USB with CD or HDD, or the internal HDD or SSD drive) appear. I'll post pictures to make it easier to explain:
    https://i.imgur.com/WZr6UT4.jpg
    Boot options (as you can see there are none, only to enter the BIOS)
    https://i.imgur.com/ZhbL7ab.jpg
    BIOS settings:
    https://i.imgur.com/P2PpfYm.jpg (as you can see, it's recognizing my drive in it's SATA location)
    https://i.imgur.com/b6i0LaV.jpg
    https://i.imgur.com/LC1g1yh.jpg
    https://i.imgur.com/UTjESUz.jpg
    https://i.imgur.com/I2p7SbL.jpg
    Any advice is greatly appreciated.
    Vasudev likes this.
  2. alexhawker
    alexhawker Spent Gladiator
    Can you confirm the drive has not failed by putting it in or connecting it to another machine?
    Grimm6Jack likes this.
  3. robbug
    robbug Notebook Enthusiast
    How was the drive prepped before? (RAID?) Did it work before? When you say never boots up is this an "old" drive from another computer?
  4. Grimm6Jack
    Problem solved, just had to flash the bios by removing the battery for a few minutes and everything went back to how it was.
    robbug likes this.
