problem removing intel proset wireless
Discussion in 'Dell' started by gregdw86, Dec 30, 2006.
  1. gregdw86
    gregdw86 Notebook Geek
    I want to remove the Intel Proset/wireless and just use the Windows wireless thing instead. I uninstalled the proset/wireless software but it completely removed the driver for the wireless card in the process so now I have nothing. I did a system restore to put it all back. Now, how can I uninstall the proset software but still be able to manage wireless connections with Windows? I did this once before when I decided I didn't want the Intel proset/wireless, but that time it left the windows wireless alone. Any help is appreciated.
  2. jim6172
    jim6172 Notebook Evangelist
    there is a checkbox in the intel software to let windows manage wireless and another box to not show icon
    jim
  3. gregdw86
    I know, I want to remove the Intel proset software because it adds too many extra running processes and a couple more things to the startup objects. The only advantage I see that it has over windows's wireless is that it connects/disconnects a little faster, which isn't that important to me.
  4. gregdw86
    nevermind, I think I got it. I uninstalled Proset, leaving me with no wireless card driver at all, then hit "rollback driver" in the device manager and then update driver, where it then found a driver in C:/windows somewhere and now it works and I only have the windows wireless thing. does that sound ok, do you think i messed anything up doing it this way?
    Under network connections, it's listed as "wireless network connection 2" though, I don't know why it was named 2. I just renamed it 1.
  5. mr_bots
    mr_bots Notebook Evangelist
    If everything is working fine, then you probably didn't mess anything up.
  6. gregdw86
    alright, cool. seems to be working fine.
  7. jhu
    jhu Notebook Geek
    just out of curiosity - why do you want to use the windows wireless manager instead of intel's?
  8. jujube
    jujube Notebook Deity
    I believe he thinks the Intel has too many processes running and slows down his boot time? I too uses only the bare minimum and had all the Intel proset turned off via msconfig and removed them in the registry as well.
  9. Syndrome
    Syndrome Torque Matters
    I use windows over intel, I just like it better that way.. with all the securities that I have on my wireless networks then it was just easier for me to go with windows.
  10. mr_bots
    The Intel software includes about 8 processes that eat up a lot of memory.
