Problem regarding my laptop gpu
Discussion in 'Gaming (Software and Graphics Cards)' started by Justin shank, Dec 7, 2017.
  1. Justin shank
    Justin shank Newbie
    Hi my name is Justin and was wondering if I hook up a external GPU to my laptop using a pcie x16 expansion card when I understand hook it will I still be able to use my laptops GPU and what are the steps on doing so
  2. JRE84
    JRE84 Notebook Evangelist
    There's sub forum in here on egpus
    If you mean using both at the same time.. No you can't
  3. Darker01
    Darker01 Notebook Geek
    Go here for all resources concerning eGPUs.
    Depending on the implementation of the eGPU adapter, the presence of Optimus on the laptop, and the laptop itself, you can have both the eGPU and the dGPU active at the same time.
