Problem changing boot order!!!
Discussion in 'Acer' started by ByggareBob, Jun 13, 2006.
  1. ByggareBob
    ByggareBob Newbie
    I can not change the boot order on my Acer Aspire 5672!
    I want to install, from scratch, Vista Beta 2 and it won't boot from the cd and therefore I am trying to change the boot order so that the cd/dvd is first.
    I have a Swedish keyboard layout but when pressing the keys only results in the computer beeping!!! I have tried every key and it doesn't work! I have tried both the "standard keyboard" and with the "numeric keyboard"
    Any clues?
  2. Arla
    Arla Notebook Deity
    Quick and dirty, when computer is booting press F12, that should take you into a boot menu (I'm assuming here, 8204 it's that, I would think it's the same on the 5672) and then choose CD drive.
    Alternatively, read the instructions, it's not "numeric" keys you press to change boot order, but I don't recall what it is (think it's + and -, but again, I don't recall, I never change the boot order, just use F12 boot).
  3. Amol
    Amol APH! NBR Reviewer
    If I remember right,it's F5 and F4 or F5 and F6 to change boot order...did you punch the right buttons?
  4. ByggareBob
    ByggareBob Newbie
    Well... The thing is I can access the bios setup correctly but I can not make any changes, it doesn't respond to "+" or "-". I will try F12!
  5. Drio
    Drio Notebook Geek
    You may have to enter your BIOS with supervisorpassword instead of userpassword.
    hth
    Drio
  6. ByggareBob
    ByggareBob Newbie
    Thanks! Using the F4-F6, can't remember did the trick!
