Preliminary results of Quadro P5200m and GTX 1070m on M6700
Discussion in 'Dell' started by RMSMajestic, Feb 19, 2019.
  1. RMSMajestic
    RMSMajestic Notebook Consultant
    is it 1070 on M6700?
  2. mirage_bg
    mirage_bg Notebook Evangelist
    No, 1070 on HP 8770W
  3. DaMafiaGamer
    DaMafiaGamer Notebook Deity
    I absolutely love the old HP Elitebooks over dells precisions, they are stronger and have much better panels, not to mention that the 8770w had edp at the time for dreamcolor!!!
    You could install the new RTX Quadro in that thing, it might boot if you load the vbios into HP's bios chip, cant say the same for a dell precision.
    To be fair that HP at the time cost a good thousand over the precision rival.
    mirage_bg likes this.
  4. mirage_bg
    Exactly my thoughts. 8770W is hell of a machine! Built like a tank!
    DaMafiaGamer likes this.
  5. TheQuentincc
    TheQuentincc Notebook Consultant
    The M6700 also have eDP capabilities, I'm running it right now with a 4k panel, the M6700 bios issue for GPU upgrade is really killing it sadly, for sure using a 1060 or a 1070 (or even a 1080) in the M6700 would have been a lot cheaper and a more powerfull solution for gpu upgrading, but to be fair a P4000 or P5000 is a good pair for and "old" quad core ivy bridge cpu, my 3920XM @4.2GHz is a pretty good match with my P4000 which I get for less than a GTX1060 while being more powerfull, I think that Quadro RTX is overkill for these old ivy bridge cpu, except if you are planing to use an high resolution monitor, but even then, you are throwing big money in an old laptop instead of upgrading to a 6 or 8 core cpu laptop :/
  6. RMSMajestic
    Sadly the cooling of elitebooks are hard to elaborate.
    TBH my favourite had been W701(ds), just the GPU can't be changed. :/ (The only imperfection of W701 is the position of RHS USB ports.)
  7. jaybee83
    jaybee83 Biotech-Doc
    are you able to oc the vram? that could still be doable.
    Sent from my Xiaomi Mi Max 2 (Oxygen) using Tapatalk
  8. TheQuentincc
    everything is locked, I'm looking about 86.04.2E.00.2C vbios, and also for those who have a P3000 and want to upgrade the M6700 gpu, you should try this vbios, it is very similar to the P5000 vbios
    jaybee83 likes this.
  9. supermoth
    supermoth Notebook Consultant
    Just out of curiosity,Will the mxm version rtx 4000 work on the M6700?
  10. Aaron44126
    Aaron44126 Notebook Prophet
    No one has tried it yet, but it is likely that it will have the same issue that Pascal cards have, causing a lock-up at boot as the BIOS hands off to the OS.
