Preliminary results of Quadro P5200m and GTX 1070m on M6700
Discussion in 'Dell' started by RMSMajestic, Feb 19, 2019.
  1. RMSMajestic
    RMSMajestic Notebook Consultant
    Here's the vBIOS of the more cost efficient Quadro P4000m that are said to be working on M6700. Whoever have devices can test and report here
    jaybee83 likes this.
  2. RMSMajestic
    Also the ASRock GTX 1080 mxm card will not fit on M6700 (choke in the way of heatpipe)
  3. TheQuentincc
    TheQuentincc Notebook Evangelist
    Hi, do you have any source for the P4000 working on M6700 ? Do you think the HP branded P4000 mxm (with epprom on it) should work with the vbios you provided ?
    Thanks
  4. RMSMajestic
    Source is from a good friend of mine from 51nb. trace backto qinhecat, who's a well known member of laptop modding community, he has modded GTX 780m/880m to K5100m before
    The P4000m vBIOS should behave more or less same as Quadro P5000m vBIOS that I've posted.
    Though I have no device to test it. I already have megatons of mxm cards and have no intention to get another one.
    TheQuentincc likes this.
  5. TheQuentincc
    Okay thanks you :)
  6. mirage_bg
    mirage_bg Notebook Deity
    Did you manage to get this HP’s P4000 working on your M6700?
  7. TheQuentincc
    For now I don't have the card, it is on transit.
    If you want to buy one from the UK seller, ask for a price in pm, I got it for 250GBP + shipping instead of 300GBP + shipping which is a deal breaker even versus a GTX1060 (less powerfull) :)
    But I think that maybe I will need an eDP lcd in order to avoid optimus, I already have the vbios flashed onto a 3.3v epprom waiting to replace the actual one, and I just need to find a 17.3" 40pins eDP QHD 120Hz or FHD 120Hz with good latency and color accurency
  8. mirage_bg
    Would you upload the vBios .rom file which you have prepared, so I can eventually use it?
  9. TheQuentincc
    It's right here :
  10. RMSMajestic
    Reminder: pascal cards uses 1.8V EEPROM chip. I can't remember the exact model but you can find it through bigger google images.
Similar Threads - Preliminary results Quadro
  1. jojonono
    2
    463
