Preliminary results of Quadro P5200m and GTX 1070m on M6700
Discussion in 'Dell' started by RMSMajestic, Feb 19, 2019.
  1. DaMafiaGamer
    DaMafiaGamer Notebook Evangelist
    Exactly, you can always overclock to make up for the decrease in performance too.
    jaybee83 likes this.
  2. User32
    User32 Notebook Evangelist
    If only HP didn't have such a godawful keyboard layout, i'd be all over a ZBook 17!
  3. RMSMajestic
    RMSMajestic Notebook Consultant
    Dude at least they are much better than lenovo. I'd love to use my W701(ds) as my daily driver however it's stuck with FX2800m/FX3800m, which are even worse than HD 6670m/HD 5450m.
    I'd love to throw 8740w in the storage. but it's the only 16:10 that is capable of carry somewhat acceptable GPU unfortunately.
  4. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Alienware M17x R2 is 16:10 1920x1200 RGBLED, it accepts 8970M so they're also that. I've been meaning to test with W7170m
    Where did you source your P5200 from? I would like to try in the M18x via optimus. Too bad you live in NOVA....bring your toys down to Richmond and lets make some experiments lol
  5. DaMafiaGamer
    These are exceptions I would make just to have a laptop with a proper mxm socket.
  6. RMSMajestic
    Okay So I have tried the 30+ unverified vBIOSes found on TPU database including the one with hardware ID 1BE1 and 1BA1
    In short answer, no luck. Either BSOD, or no display. The best I can get in boot without display, with the attached vBIOS. I can enter the BIOS and change settings with Henrik's vBIOS, but not booting into the system (Already safe mode DDU cleaned)
  7. Aaron44126
    Aaron44126 Notebook Virtuoso
  8. JEAMN
    JEAMN Notebook Guru
    Yep.
    In particular, if you are getting a BSOD for Win10, it's worthwhile to setup a Win7 usb installer. Win7 will actually display error information on screen that can help pinpoint the problem.
  9. RMSMajestic
    I don't have winbugs 10 in the first place, skip that spyware.
    BTW could you please help me modding a BIOS for M6700? I've seen you having a success in M6800
  10. JEAMN
    JEAMN Notebook Guru
    Nothing I did with the vBIOS helped. I'm using the OEM vBIOS and use a custom boot loader to patch the ACPI tables before booting Windows. It's basically a hack that UEFI secure boot was designed to prevent. =)
    If it's the same problem for the m6700, my solution would probably work for it as well. Are you using Win7 or Win8? Win7 should be giving you some error codes if you are getting a BSOD. If so, could you post them? That'd give us a place to start.
    Blossomcrown likes this.
