Powerful, Thin-Light, High-Quality Laptop
Discussion in 'What Notebook Should I Buy?' started by Xero, Sep 18, 2012.
  1. Xero
    Xero Notebook Consultant
    I'm looking primarily for a thin (at least under an inch) and light (at least under 4lbs), powerful laptop (i5 or i7 non-ULV) for college. I recently bought a Vaio Z3 and I'm loving it, but seeing as I spent $2426 on it, I think I could do better for the price.
    1) What is your budget?
    $2000 Max (Ideal would be $1500)
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" - 16" screen (Would have to be extremely appealing with top tier specs and much cheaper)
    USA
    a. Like: Sony
    b. Dislike: The cheap, low quality stuff
    No.
    College life, Programming (computer science), maybe some light gaming (don't think too much about gaming as I have a gaming PC)
    Mainly with me.
    Not really as I have a Gaming PC, but some games I would consider playing are Guild Wars 2, Aion, Dark Souls, and other steam games.
    5+ (excluding gaming of course)
    Would prefer to see them of course, but I don't mind ordering online first as long I have resonable open return time frame.
    11) What OS do you prefer? Windows (XP or Vista or Windows 7), Mac OS, Linux, etc.
    Windows 7 and maybe Linux.
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. Click here for Screen resolution information.
    1600x900 (Minimum)
    1900x1080
    13) Do you want a Glossy/reflective screen or a Matte/non-glossy screen?
    A very good matte or glossy screen (Needs to be usable in sunlight)
    Build Quality and Design
    Yes, very important. I'm not buying something I don't enjoy looking out.
    ASAP.
    As long as possible, ideally 4+ years.
    Notebook Components
    17) How much hard drive space do you need; 80GB to 640GB? Do you want a SSD drive?
    SSD, 256 minimum.
    18) Do you need an optical drive? If yes, a DVD Burner, Blu-ray Reader or Blu-Ray Burner?e
    Nope.
  2. 491450451
    491450451 Notebook Enthusiast
    I think SONY VAIO Z is the only choice satisfying you.
    Sony Vaio Z, though i don't own it, is worthwhile.
  3. Amal77
    Amal77 Notebook Deity
    I am very happy with my Vaio S13P.
    Though you could also look at Gigabyte U2442N.
  4. Xero
    I don't like the screen or track pad in the S13P.
    I'll check out the Gigabyte, but 14" should have a 1080 screen jmo.
  5. Karamazovmm
    Karamazovmm Overthinking? Always!
    you can either wait for the rmbp 13, which we dont know pretty much nothing about it, or just go on with your vaio z13
  6. aspectratio1
    aspectratio1 Notebook Enthusiast
    Have you looked at the
    Series 9 15” Notebook $1,799.99
    NP900X4C-A03US
    Series 9 13.3” Notebook $1,699.99
    NP900X3C-A04US
  7. Jarhead
    Jarhead 恋の♡アカサタナ
    Don't think there's anything wrong with the Vaio Z, except maybe keyboard quality (compared to something like a Thinkpad keyboard).
    If you'd rather have a better keyboard, but give up high-res, the Thinkpad X230 might be worth a look.
  8. kanuk
    kanuk Notebook Deity
    I can see why you would find the S13P's screen lacking compared to the Z, but what's wrong with the trackpad? It's one of the best non-Mac trackpads I've tried.
  9. CheddarTrek
    CheddarTrek Notebook Geek
    Strongly suggest you check out the Thinkpad T430 and T430s.
    Pretty sure there's space in the T430 at least to have both a hard drive and an SSD too.
  10. Karamazovmm
    there are 3 main problems with the z13: trackpad (awful, jumpy), keyboard (shallow with ''wrong'' spacing), build quality (flimsy as hell)
