Power2go missing file P2GRC.dll
Discussion in 'Windows OS and Software' started by Chris Redfield, Oct 27, 2008.
  1. Chris Redfield
    Chris Redfield Notebook Consultant
    Help....
    I'm getting an error while trying to open the Cyberlink program "Power2go". After i clicked to that program an pop up window appears and said: The file [language\\P2GRC.dll] is missing. Please reinstall application.
    How could i fix this? I haven't found any Cyberlink reinstaller in order to get the missing file
    Thanks,
  2. Shyster1
    Shyster1 Notebook Nobel Laureate
    Try installing from the original installation package you got.
  3. Chris Redfield
    The problem is that that program was preinstalled with my laptop, and they didnt include the installations disk to install.
    I try to search any installation disk at my laptop files or in the website and i couldn't found anything :( . Nevertheless i got the Nero 8 but i wish to try the features of this program also.
  4. Shyster1
    Do you have recovery CDs, or a recovery partition? Usually, the bloatware that's preinstalled is tucked nicely into the recovery CDs/partition preinstalled systems come with, so you might be able to recover the .dll that way.
    Also, have you actually searched your system to see if you can find that file? It might simply have been "misplaced" or the registry link to it broken by something else you installed (like another competing CD/DVD burner app).
    If you find it, try re-registering it to see if that fixes the problem.
  5. Chris Redfield
    Ok, i will try to do that then, i post later if it works, thanks
  6. Shyster1
    Well, first see if you can locate a copy of the .dll on your system by searching; if you do, let us know.
  7. Chris Redfield
    Nope, i didnt find anything in my system :(
  8. Cuedup
    Cuedup Newbie
    I'm having the same problem...missing the P2GRC.dll file.
    Does anybody know whether Chris was able to find a solution?
    Thanks.
  9. Chris Redfield
    I had to go to this path at the swsetup:
    C:\SwSetup\CyberDVD
    And reinstall the Cyberlink DVD Suite and it worked so far... it's good to maintain the setups files for those files.
    Good luck
  10. richo64
    richo64 Notebook Guru
    My guess is that you have a HP laptop. Did you update the Quickplay software by any chance? This is known to happen after updating/reinstalling Quickplay. I would suggest backing up your Swsetup folder to a portable harddrive or flash drive so you don't lose it. Also would suggest making back up disks... there is a program provided to do this... usually needs 2 or 3 blanks DVD's.
