Power problem : lights and fans come on for a second then the lights stay on and the fans shut off
Discussion in 'Alienware M15x' started by Clarent, Jan 18, 2020.
  1. Clarent
    Clarent Notebook Enthusiast
    Does that means i have ic power problem or? If it because ic power i could fix it
    I really need this laptop for my thesis
  2. Maxware79
    Maxware79 Notebook Evangelist
    Sounds like a hardware problem. Firstly I would try one stick of memory at a time but it really could be a number of things. I think these old machines used the lights as a diagnostic code instead of the beep code system. Do you get a pattern of lights on the keyboard panel?
    It's been years since I had an M15x so I can't really remember the layout.
  3. Clarent
    What is the indicator if the vga is broke?
  4. blazeghost
    blazeghost Notebook Guru
  5. MatsueMaiku
    MatsueMaiku Notebook Geek
    I was thinking it could be a memory problem as well. I just had a very similar thing happen with my PC. It turned out to be faulty memory.
