Power Management for Vostro
Discussion in 'Dell Latitude, Vostro, and Precision' started by Trailryder, Jan 22, 2020.
  1. Trailryder
    Trailryder Notebook Guru
    Hey all. Can’t seem to find a Dell Power Management Software version to evaluate the battery for my Vostro 1510.
    I’ve tried 2 versions. One wouldn’t install, said it was incompatible, the others functions was severely curtailed.
    Have any leads?
  2. Aaron44126
    Aaron44126 Notebook Prophet
    AFAIK, the Dell Power Management software was introduced in 2013 and works with systems having Intel 4th gen CPUs (Haswell) and up. Vostro 1510 is a good deal older than that.
    Vasudev likes this.
  3. Trailryder
    Thanks.
  4. Trailryder
    I found this Windows command: powercfg /batteryreport
    It saves the report in Users folder of the C: drive
  5. Aaron44126
    I didn't realize that you were just trying to get some battery info. You can use hwinfo64 and it should produce some details on wear level, maximum capacity, etc.
    Trailryder likes this.
