Power Adapter - hot hot hot!
Discussion in 'HP' started by tiesto81, Mar 27, 2007.
  1. tiesto81
    tiesto81 Notebook Geek
    Does anyone else's brick portion of their power adapter get hot? I mean - i'm almost scared to leave it on my sofa cushion while I use my laptop. It's pretty hot to the touch.
    I'd leave it on the ground if I could but the length of the cord is too short. I'm just seeing if this is normal.
  2. agent007
    agent007 Notebook Consultant
    I noticed mine gets hot when the battery is low and is in the charging stage.
  3. deedeeman
    deedeeman Notebook Deity
    mine gets hot, but not tooooooo hot, its just like "warm"......but for your question, i would rather not put it on the sofa (fire hazard)
  4. vassil_98
    vassil_98 Notebook Deity
    Every once in a while, somebody checks his/her adaptor and finds out its hot...Don't worry it's absolutely normal. The temp of the adaptor depends on the supplied electricity, the ambient temperature, the amount of power the laptop draws, etc. There's also difference if you are in Europe, USA or Australia (different standards of power characteristics)
  5. samiroma
    samiroma Notebook Enthusiast
    I have a dv8000 and dv9000 both bricks get so hot I cannot touch them and also am afraid of the fire hazard. Hp says its normal. I say its ridiculous. One is a 65watt (dv8000), the other is a 90watt (dv9000), and in charging mode both get that hot. What model do you have?
    Sami.
  6. oakenshea
    oakenshea Newbie
    I take a heatsink from an old motherboad or CPU and attach it to the "brick" with an elastic. This keeps the "brick" a bit cooler. : )
  7. j3oomerang
    j3oomerang Notebook Guru
    lol, are you serious?
  8. Brendynj18
    Brendynj18 Notebook Enthusiast
    I have a small wood box i use to prop the brick up so it does not make the carpet so hot!... this is for my c500 though... don't know why it gets that hot... the computer seems to get very hot to... to the point i have to take it off my legs!
  9. flipfire
    flipfire Moderately Boss
    I sit my brick below my laptop cooler but yes it does get quite hot
  10. jong81
    jong81 Notebook Consultant
    Mine gets oooooooober hot - like hotter than Jessica Alba naked hot. Like, can only put my finger on it for 10 seconds hot. Like, I use it to fry my eggs in the morning hot.
    Okay - it's pretty hot, but only when charging the battery.
