  1. Tinderbox (UK)
    Tinderbox (UK) BAKED BEAN KING
    Vasudev likes this.
  2. katalin_2003
    katalin_2003 NBR Spectre Super Moderator
    I can post just fine (post deleted now).
    What happens when you press the "Post reply" button? Any errors?
    Try disabling your browser's extensions temporarily and try again.
  3. Tinderbox (UK)
    The post reply button goes from orange to gray, and then in about five seconds back to orange, the page does not reload or anything (no errors), I deleted all today`s browser data everything, still no good.
    I did virus and spyware scans nothing.
    It must just be a browser fault, I will remove and re-install tommorow and see if that fixes it.
    I did not want to create a thread if it`s only a browser issue.
    Thanks
    John.
  4. Tinderbox (UK)
    edit i disabled all my extensions and re-enabled them 1 by 1,
    It turns out it was uBlock Origin, dated 17 July 2018 that was the problem, I had tried setting NBR to non blocking but it still caused me the posting problem, I had to totally disable it.
    Strange how i could post in other parts of NBR but not in that thread.
    Thanks
    John.
    Vasudev likes this.
  5. jeremyshaw
    jeremyshaw Big time Idiot
    It's the thread name. @Tinderbox (UK)
    Code:
    http://forum.notebookreview.com/threads/avast-is-ruining-ccleaner-malware-bundled-software-popup-ads-whats-next.821059/add-reply
    Code:
    ...eview.com/threads/avast-is-ruining-ccleaner-malware-bundled-software-popup-ads-whats-next.82...
    Code:
    ...ing-ccleaner-malware-bundled-software-popup-ads-whats-ne...
    Code:
    ...tware-popup-ads-what...
    Code:
    -popup-ads-
    "-popup-ads-" is what triggers "EasyList" within Ublock Origin.
    Vasudev, Tinderbox (UK) and downloads like this.
  6. Vasudev
    Had the same issue as well.
