Possibly new Idea for optical bay... Custom second battery modded/wired into stock?
Discussion in 'Alienware 14 and M14x' started by shnarf, Dec 31, 2012.
  1. doniGforce
    doniGforce Notebook Geek
    wow, really nice idea, I'm thinking I can design an internal switching circuit to switch the batteries when they're charged. If somebody can cram the same number of cells and with the same specs in the ODD space and by any chance find the chip of the original batteries (Samsung) (dead batteries anyone).
  2. funkmasterta
    funkmasterta Notebook Evangelist
    I don't see why you'd have to merge, ie, splice together any wires.
    Just go to Mouser Electronics - Electronic Components Distributor or DigiKey Electronics - Electronic Components Distributor
    Buy 2 x female connectors for the battery.
    Buy 1 x male connector for the motherboard.
    Buy a toggle switch that has 8-10 contacts on each side (it looks like the battery has 8-10 wires).
    Solder everything together.
    Test it and make sure the toggle switch works.
    Then, disassemble the 2nd battery and reconfigure it to fit into the ODD bay.
    Mount toggle switch onto chassis.
    Profit!
    It's totally possible to do this.
  3. Alienware-Luis_Pardo
    Alienware-Luis_Pardo Guest
    An extra battery? That is sick, I never use my ODD anyway.
    Let us know if you try it
