Possible to wire 12v laptop fan to Desktop fan controller?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Reciever, Nov 18, 2019.
  1. Reciever
    Reciever D! For Dragon!
    I have one of these fans...
    https://www.ebay.com/itm/Original-N...681463?hash=item469a508ef7:g:56cAAOSwi6tdO~w0
    I am curious if its possible to rewire (if needed) to work with a desktop 4 pin connector? If anyone knows the layout for the fan I can probably figure out the desktop pin out side as thats standardized.
    The laptop fan is 12v 0.45a
    This is the fan controller I am using.
    https://www.amazon.com/Kingwin-FPX-...-Independent/dp/B00DP9WRZY?ref_=fsclp_pl_dp_3
    I would like to use it as part of a CPU cooling overhaul project I am working on.
    Thanks guys
  2. bennyg
    bennyg Notebook Virtuoso
    Given the colours are pretty standard, red is +DC, black is gnd, yellow is rpm sense (sent from fan), blue is pwm
    Whether the pwm signal range of the fan works nicely with the fan controller is the question.
    Reciever likes this.
  3. Reciever
    Thank you so much!
    I had no idea the color coding was standardized as well, my Rangers fan cables are all black, though they are aftermarket.
    I want to knock out a bunch of modding on the Turkey Day holiday so this info has been most welcomed!
    Fan is actually 12v / 0.6a though, not sure if that matters too much (not an electrician)
    Now I just gotta desolder the heatsinks I have for their parts and get to overhaulin
