Possible to upgrade PC-Card Slot to ExpressCard?
Discussion in 'Lenovo' started by stebesplace, Mar 19, 2008.
  1. stebesplace
    stebesplace Notebook Enthusiast
    I have an R61, and stupid me, ordered it with the PC-Card/Smart Card Reader instead of the ExpressCard. I am not sure if this is something built into the motherboard, or if this is something I can source the module for, and (probobly voiding warranty), replace with the ExpressCard module? Let me know if this sounds stupid, or if anyone has actually done this. I can't believe I bought it without ExpressCard. What was I thinking!!!
  2. jnorman5
    jnorman5 Notebook Consultant
    I don't know about that but I know you can buy an adapter. It simply slides into the PCMCIA slot and it allows you to put in an express card. Hope that helps.
  3. stebesplace
    Yeah but the adapter would not have the speed of a true ExpressCard bus if I recall. Still that is an option yeah.
  4. msb0b
    msb0b Notebook Consultant
    The part is replaceable, but you will need to practically dismantle the whole computer. Look up the Hardware Maintenance Manual (HMM) for your machine type. You will find the part number and the directions. And yes, they will void your warranty.
  5. stebesplace
    I wonder if a 3rd party "certified"? retailer, or even lenovo, can upgrade that for me? Would probobly cost a small fortune i guess in the end...
  6. msb0b
    That I would not know.
