Possible to replace US keyboard with Belgian Azerty?
Discussion in 'Dell Latitude, Vostro, and Precision' started by nesdnuma, Jul 16, 2019.
  1. nesdnuma
    nesdnuma Notebook Guru
    Hello,
    I am considering buying a second-hand Precision laptop in the US.Is it possible to replace the US keyboard with a Belgian Azerty?
    Thank you for helping.
  2. Aaron44126
    Aaron44126 Notebook Prophet
    Yes, in all Precision systems, you can replace one keyboard with another without trouble.
    For systems that have "chiclet"-style keyboards (plastic trim between the keys) you will need to make sure that the keyboard you are putting in matches key positions of the one you are replacing. (Check around the Enter and backslash keys specifically.) If they do not match up, you will need to order a new chiclet/bezel as well.
