Possible to replace GS70 TN panel with IPS?
Discussion in 'MSI' started by Coprhead66, Dec 10, 2015.
  1. Coprhead66
    Coprhead66 Notebook Enthusiast
    Hello everyone,
    Is it possible to do this? Does anyone have any 17" IPS panel recommendations? This is my only gripe with the machine. Everything else is perfect!
  2. Kevin@GenTechPC
    Sure, it is possible, we just need to figure out which panels are compatible.
  3. Coprhead66
    Well if Kevin from GenTech can't figure it out, nobody can! I believe in you Kevin...
    Kevin@GenTechPC likes this.
  4. Meaker@Sager
    Well it does depend on the type of internal connector used which may vary depending on the generation of GS70 you are talking about.
  5. Kevin@GenTechPC
    I will try to get a list for you if I can, cannot guarantee it though, but I will try.
    Thank you for believing in me. :D
  6. iTzZent
    iTzZent Notebook Consultant
    only the current versions of GS70 with eDP connection can be upgraded with an IPS display. This can be seen, inter alia, the built-up display. ChiMei N173HGE-E11 is a eDP display and ChiMei N173HGE-L11 is a LVDS display.
  7. Meaker@Sager
    At least they made the model numbers easy to read that way :) Otherwise there are no IPS 40 pin LVDS 17.3" panels, that's why it has to be eDP.
