Possible GPU upgrade for Precision M4600
Discussion in 'Dell Latitude, Vostro, and Precision' started by garmac, Mar 6, 2015.
  1. KhronX
    KhronX Notebook Consultant
    You can't physically modify mainboards via BIOS updates, sadly...
  2. John Carlson
    John Carlson Notebook Consultant
  3. KhronX
    Isn't that virtually the same thing as the RX560 (albeit officially the cut-down version), for three times the price, and yet-unknown compatibility with laptops (thinking of video BIOS issues here)?
  4. TheReciever
    TheReciever D! For Dragon!
    In a nut shell, yes.
    And also have yet to see anyone with them either.
  5. John Carlson
    E9260 MXM uses only 50W while RX560 MXM needs 80W to run.
    So I think E9260 card will run cooler than RX560 although I think RX560 will likely run on M4600.
    Overall, RX560 has better spec. RX560 is faster.
  6. John Carlson
    RX560 is a better deal for the price, yes.
    I'm wondering what that E9950 MXM A card will be like. It has 8GB memory for MXM A size!
  7. KhronX
    Underclock the RX560 and you'll get into (or at least really close to) the power envelope of the E9260, so there's no mystery or rocket-science going on there.
    https://www.amd.com/Documents/ultra-high-performance-gpu-product-brief.pdf
    The E9550 is basically a full-fat RX480/580, but i'm hiiiiiighly skeptical they can (or will) shoehorn it into an A, and/or the "A" there is not a typo.
    One thing that's sure to be, is expensive as **beeeeep** (if the E9260's anything to go by).
  8. John Carlson
    Yes.. it's going to be crazy if they make it into an A card..
  9. KhronX
    In my case, the cooling (which is downgraded since / from the M4600) definitely won't be able to handle it.
    PS: A quick search revealed that that is very much indeed a typo in that roadmap of theirs:
    https://item.taobao.com/item.htm?sp...RhnowB&id=563308143366&ns=1&abbucket=3#detail
    That being said, that's nowhere near as pricey as i was expecting, actually. I figured it had to be at least +50% of the E9260... Although at that price, it's comparable to what i've read some desktop boards might go for, nowadays (what with the cryptomining stuff).
    But still damn expensive - my whole M4800 might be worth around that much :D
  10. John Carlson
    right.. RX560 is the best MXM A graphic card deal of our time.
    No other card comes close to its spec and price.
    If it works, it will turn all M4600, M4700 Dell Precision series into newer, powerful gaming & mobile workstation laptops that can beat Asus GL553 which costs $1,300 to purchase as new.
    RX560 M4600 will rival spec of Asus Zephyrus with 1060 Max-Q.. RX560 is on par with 1060 Max-Q. Asus Zephyrus costs $2500 to buy as new and I don't think that's relevant amount of money to spend on a laptop.
    https://www.newegg.com/Product/Prod...m_re=Asus_Zephyrus-_-9SIA7AB6ME5400-_-Product
    Asus Zephyrus with 1080 is my dream laptop. They indeed crammed GTX 1080 into a 15 inch laptop.. but it has only 1 hour battery life and costs $2500 minimum.
    I doubt Zephyrus will come with a better keyboard than M4600 keyboard though.
