Possible display/graphics issue. Ideas?
Discussion in 'Sager and Clevo' started by RealBACONATOR2, Oct 12, 2018.
Tags:
  1. RealBACONATOR2
    RealBACONATOR2 Notebook Enthusiast
    I'll post an image here, but basically I'm having intermittent display issues.
    Clevo P650SG/Sager NP8652, i7-4720HQ, GTX 980M, IPS display
    Sometimes, caused by moving the lid or by seemingly random causes, the display will flicker or "stick" on a colors+lines image. The image it gets stuck on is based on what is on the display at the time. And it is always resolved by closing the lid and re-opening it.
    I don't have any external monitor.
    Is there a different way to determine whether this issue could be resolved by installing a new display? Or if it is a graphics card error? Running latest nvidia driver.
  2. Danishblunt
    Danishblunt Guest
    looks like you need to open your notebook and put the cable properly in again.
  3. Chastity
    You probably have a loose vid cable
  4. Meaker@Sager
    Use some kapton tape to ensure it stays in if there is none there or to replace the old tape.
  5. Latostno
    Latostno Notebook Enthusiast
    It looks like a loose cable issue and you will need to open your laptop to fix that. Check YouTube, there should be a video telling you how to do.
  6. RealBACONATOR2
    Thanks for the advice everyone. I replaced the tape with some good electrical tape that was super tacky. While the display issue appears to happen less frequently, it still occurs. Is there some other connection I can check for a loose/degraded cable? What about the other end of the cord?
  7. Meaker@Sager
    Yes, the other end into the laptop is also worth checking.
  8. RealBACONATOR2
    Thought I would post another update. I think the motherboard side was the one at fault. On the P650SG the monitor cable connects to the motherboard near the exhaust fan under the ESC key. The connector snaps in VERTICALLY, NOT HORIZONTALLY so you lift straight up on it to disconnect it. It has a black plastic tab to help you lift up on it. It wasn't taped down or anything, so I could see how it may pop loose. I blew some of the dust out from under the connector and we'll see how it goes.
  9. RealBACONATOR2
    2nd update. The display issue is intermittent but still there. My particular P650SG has a 40-pin connector and LP 156WF4-SLB5 IPS display. Ordered a new 40-pin cable for like 20 bucks and I'll see if that works. The display is like $60, so I'm going to try to fix the cable and see if that changes things.
    Does anyone have a suggestion for a 40-pin 1080p IPS matte display with better than 400:1 contrast ratio?
  10. Meaker@Sager
    Check panelook, it's a good way to look.
