Possibility to run straight 12v for mobile use?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by freewilly, Jan 24, 2012.
  1. freewilly
    freewilly Notebook Enthusiast
    I don't know if this has been addressed before, but I was wondering if, instead of the inverter/power brick setup currently in use for mobile (car) applications, a person could run a laptop off straight 12v DC? Looking at my buddy's laptop the other day I noticed that while the power supply put out around 19v, the battery was rated for a bit over 11v. What would happen if one were to simply input 12v (with the proper polarity) into the DC in?
  2. whitrzac
    whitrzac The orange end is cold...
    If the '12v' on a car was regulated, it might work. The problem is, its not. The voltage can range from 11v-16v at any given time.
  3. freewilly
    I'll have to take a look, but it's not uncommon to see electronic devices that, on the back sticker, have a solid upper line (high limit) with a dashed/dotted lower one when the input voltage is specified. Generally, the low limit is not spec'd but the internal voltage regulator can handle quite a range. That's not to say that the same would hold true for a laptop.
    I was also thinking that, especially with a battery that wasn't being charged while in use, that the voltage would not be subject to much in the way of 'spikes'.
Similar Threads - Possibility straight mobile
  1. _H_
    584
