Portable laptop for student, light gaming
Discussion in 'What Notebook Should I Buy?' started by marcv123, Jul 3, 2018.
  1. marcv123
    marcv123 Notebook Enthusiast
    Hi all, looking for a laptop to buy now to take to college. Will be used for some gaming, but also taking to classes and studying. Under 5lbs would be great, so anything in the 13-15" range would be good. Dedicated graphics card is a must, but does not need to be super fast.
    This is replacing a Lenovo edge2 with a NVIDIA GeForce 940M, so anything equal to or more powerful than this should be fine.
    So far, it seems the XPS15, Dell G5 or G7, or Lenovo Y530 seem good, but I am open to comments on these or others.
    Thanks for your help!
    General Questions
    1) What is your budget?
    $1400
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" max
    Weight is important too...ideally under 5lbs.
    USA
    Do not really care.
    no
    mid range gaming (world of warcraft, starcraft. No fps where high framerate matters.). Also, will use for college classes.
    Taking it with
    Yes, world of warcraft, starcraft, warhammer, etc.
    not a big deal, as long as it lasts well when not gaming.
    on line ok
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Windows
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    Don't really have a preference.
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Build Quality and Design
    Prefer something looking pretty mainstream, without a ton of neon or flash. So things like Dell, Lenovo, etc would be preferred over a gamer's look.
    asap
    2-3 years
    Notebook Components
    no
  2. gnlu26
    gnlu26 Notebook Consultant
    I think you were right on the money with the Dell G5 or G7. They seem to have the best bang for buck right now, and dells support is really good if you get the premium option. For light gaming the XPS will probably still work pretty well, the 1050Ti will still be much more powerful than that 940m. Not too sure about the Lenovo, haven't seen much on it, but their quality is usually pretty iffy. The build quality on the G3/5/7 is pretty darn good for the price.
