Portable and Powerful Laptop for Engineering Student
Discussion in 'What Notebook Should I Buy?' started by rmazur12, May 19, 2015.
  1. rmazur12
    rmazur12 Notebook Enthusiast
    Hello guys. I am new here on this forum. I am going to be a mechanical or chemical engineer next fall and I am looking for a laptop. I have attached the general questions below. My primary requirement is that the laptop has to be less than 1.2 inches thick and less than 5.5 lbs. I understand that cooling might be an issue with the form factor. I know that Nvidia Quadro GPU has drivers for CAD but I am concerned about the budget. Any suggestions would be much appreciated.
    General Questions
    1) What is your budget?
    Less than $2200
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" - 16" screen
    2) Where will you buying this notebook? You can select the flag of your country as an indicator.
    USA
    a. Like: No preference
    b. Dislike: Apple
    No
    Primarily used for web surfing, Microsoft office, photo editing with Adobe software, and some engineering software (AutoDesk (mainly AutoCAD and some Inventor), MATLAB, Wolfram Mathematica). I do not know the specifics of other software that I will be using.
    Yes
    Games are not my primary focus with this machine
    Hoping for between 4-6 hours but not a necessity
    Not vital but I would rather see it before purchase
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    Windows 8
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. Click here for Screen resolution information.
    I do not need 4K or 3K, standard 1080p FHD will be fine. It would be great if it has a touch screen.
    13) Do you want a Glossy/reflective screen or a Matte/non-glossy screen?
    Matte
    Build Quality and Design
    No. However, I want the laptop to be very thin and lightweight, preferably less than 1.2 inches thick and less than 5.5 lbs.
    Within the next month
    3-4 years
    Notebook Components
    Best case: 1 Tb 7200 RPM and 128 or 256 gb SSD
    Least case: 128 or 256 gb SSD
    No
    END COPY
    Please state any additional features you need. It's also helpful if you can indicate how experienced you are with computers. If you're a novice and don't know much, that's alright. Everyone's a novice at some point.
    Discrete graphics with 1-2 gb VRAM
    Processor that reaches 3.0Ghz+ with TurboBoost and has hyperthreading
    8-16 gb RAM
  2. Galm
    If you don't want gaming you have a huge budget. What do you prioritize cpu or gpu? You can get a gigabyte p35w with a 970m and an i7 4710mq which should meet your needs for 1400, or you can step it up to a p35x with a 980m for 1900-2000. Depends what you want. You can even get an SSD in them with a 1TB ssd for that price.
  3. Galm
    This would crush ur recommended specs http://www.newegg.com/Product/Product.aspx?Item=N82E16834233088 It has the highest end gpu from last year (880m) so around a 970m, and then a higher end i7 4810mq processor instead of a 4710mq. And its on sale and comes with 256gb ssd. tbh its a steal. But if you want more gaming power than that get a gigabyte with a 980m. They are the thinnest for the money. Otherwise for bulkier go Clevo or MSI GT60. Also ram wise 8 is fine but you can up it if you want, isn't too much more for the gigabytes. It is thin enough too, they are crazy thin.
  4. rmazur12
    Galm17, thank you for your input. The gigabyte would most certainly meet all of my specs. I definitely believe that I should prioritize the GPU. The 880M looks like it will work as well as the 970M and 980M for sure. My only concern about gigabyte is that I have heard that the build quality is not consistent and that customer service is terrible and/or non-existent. Also, is there a two or three year warranty with gigabyte? Should I buy through a custom configuration website, ie XoticPc?
  5. Delta_V
    Delta_V Notebook Consultant
    The Clevo P650SE (Sager NP8651) comes with an i7-4720HQ and 970M, and is about 5.5 lbs, so just a little bit heavier than the Gigabyte P35, but it has a better cooling solution. You can also upgrade to the P650SG (NP8652) which comes with the 980M. It starts at $1219 through XoticPC for the NP8651, and $1569 for the NP8652. Note that these prices do not include an operating system, but as a student, you may be able to get a free copy of Windows through the Microsoft DreamSpark program. Compare this to the Gigabyte P35, which starts at about $1450 for the P35Wv3, the 970M model.
    At this point, I would avoid the 880M. It is an overheating monstrosity, and is handily beaten by the 970M, to say nothing of the 980M. So there really is no reason to get it over a system with the 970M. Comparing the NP8651 to the Gigabyte P25X that was linked, the P25X has a slight advantage in processor, but the NP8651 has a much better GPU and is lighter. In the description in the link, it says the P25X is 5.73 lbs, but in the specs it is listed at 6.39 lbs, which agrees with XoticPC.
    Also, one final note - the Gigabyte P35W/X comes with the i7-4720HQ, *not* the i7-4710MQ. The difference is the MQ is a socketed chip, meaning it can be replaced, while the HQ is soldered to the motherboard. Also, in practice, the MQ chips can hold their clocks better under load. So if the P35 had an MQ processor, that would be a point in its favor. However, it has the same HQ processor as the Clevo/Sager, so that part is a wash.
  6. win32asmguy
  7. Delta_V
    It seems like a nice workstation, except the lack of a numpad on the keyboard is baffling. As a grad student in engineering, I hated the fact that my old notebook did not have a numpad; it made entering data exceedingly annoying. When I went to purchase a new notebook, a numpad was one of my non-negotiable requirements. I know they make USB ones, but then you have to carry the thing around.
  8. TomJGX
    TomJGX I HATE BGA!
    I would get the Clevo P650SE/SG (Sager NP8651/8652)... The 970M/980M will be more then enough for CAD etc.. It will be good enough for any games... AutoCAD doesn't need that much GPU power..
  9. win32asmguy
    Another option is the Lenovo W541 if a number pad is needed on the keyboard. It is still quite thin and light for having a full voltage processor. These models are more traditionally business machines, so they focus on warranty and build quality more than performance. They typically aren't offered with graphics cards that can run high end games. If you do need that ability, the Sager is a P651SE is indeed a great option. Alienware also offers models with an onsite warranty if you need something with a better warranty but gaming GPU.
  10. rmazur12
    Thank you all for your input.
    Delta_V, I am unfamiliar with Sager/Clevo and Gigabyte. I understand that Sager is a re-seller of the Clevo chasis. How is their customer service and build quality? I am hoping for the machine to last 3-4 years. Thanks.
    win32asmguy, thanks for your suggestion. I feel that Quadro may be overkill but the laptop is nice looking and fits my weight and thin requirement. Definitely keep it in consideration. The lenovo W541 is also nice. I am defintiely concerned with warranty and build quality which makes me nervous about Sager and Gigabyte. I will take a look at the Lenovo further. Thanks.
    TomJGX, what card do you recommend for AutoCAD other than quadro. Would the GTX 965M or GTX 960M work? Also, do you know if the Sager 8651 has a touch screen? Thanks.
