Poll how many m11x r1 users have fried their nvidia gpu due to overclocking???
Discussion in 'Alienware M11x' started by Uzii305, Jan 31, 2011.
Fried your gpu due to overclocking
Poll closed Apr 1, 2011.
  1. Yes
    2 vote(s)
    3.6%
  2. No
    53 vote(s)
    96.4%
  1. Uzii305
    Uzii305 Notebook Enthusiast
    Im jus curious cus im a little nervous about o/c my gpu
  2. tendomentis
    tendomentis Notebook Enthusiast
    Mine is still good so far, and I've been OC'ing the GPU since I bought in August.
  3. Fuzzyhead
    Fuzzyhead Notebook Geek
    As long as you don't tweak with the voltage and monitor the temperatures closely nothing should go wrong, except your GPU was a little bit weird to begin with.
  4. binro01
    binro01 Notebook Consultant
    just dont go nuts. Go up in small increments.. test for stability and temp. Remember each GPU is made in the creators image but they are each individuals and have their own characteristics.
  5. UltraNative
    UltraNative Notebook Enthusiast
    Is this meaning overclocking the GPU on the nvidia video card? How is this done exactly? (brand new laptop owner)
  6. Fuzzyhead
    you download tools like EVGA Precision and just oc your card to the desired clocks.
  7. utrillalm
    utrillalm Notebook Enthusiast
    you wont fry your card if you are always monitoring temps, but yes, it will reduce the chip life and maybe the chip will begin to cause problems maybe in 1 year, 2 years of constant OC use.
  8. vzachari
    vzachari Notebook Evangelist
    Will this happen even if the GPU is running relatively cool? With mild overclocks the GPU in my m11x R2 never reaches temps above 63-65 Celsius while gaming. I think you need to push the chip to dangerous temps/voltages to see degradation.
  9. some guy
    some guy Modding Addict
    its near impossible to mess your chip up with the stock voltage. just monitor your temps and find out what temp is the max you chip is designed for, if your load temps stay about 25% under the max temp you should never have issues.
    OC as high as you can get stable with, and then back it off 25mhz or so. ive done this with almost every CPU and GPU ive owned and none of them broke. the only time your asking for problems is if your running realy close to the max temps all the time. or if you add more voltage to the chip.
    as far as OCing reducing the life span of yout chip? again, only a issue when temps are too high and or you are sending more than the stock voltage to the chip.
  10. Fuzzyhead
    Well, there is the rumor that a increase in temperature by 10 degrees havens the lifespan of the chip.
