PLL Pinmod Overclocking Methods and Examples
Discussion in 'Hardware Components and Aftermarket Upgrades' started by moral hazard, Jun 24, 2009.
  1. XSpiritusX
    XSpiritusX Notebook Enthusiast
    It is an HP Tm2t-1100 CTO.
  2. Atom Ant
    Atom Ant Hello, here I go again
    I do not really understand how to overclock my T7500 CPU in my Dell Latitude D630. Can I ask someone to describe it for me step by steps?
  3. moral hazard
    Looks like you need to disconnect pin45 (FSLb) from whatever it's connected to, then connect it to GND.
    That should take your FSB from 200mhz to 266mhz.
  4. Atom Ant
    And where can I find that pin45 and GND? Is it something similar when I pin mod a 400FSB Dothan CPU to 533FSB? Thanks!
  5. moral hazard
    You need to find the PLL on your motherboard (it's a chip that is pretty small and has SLG8LP550 written on it).
    You can tap GND(ground) from the areas around the screw holes in the motherboard. There will also be GND pins on the PLL (should see then in the datasheet if you can find it for your PLL).
    You will need a really small soldering iron to do this mod.
  6. gasolina
    gasolina Newbie
    i'm a newbie :) after searching all over on the internet still i haven't found any guide for overclocking dell latitude e6400 . I jz want to know that is it possible to overclock this lappy :)
    //sr for my bad eng
  7. moral hazard
    SetPLL has been moved here.
  8. gasolina
    gasolina Newbie
    @moral hazard will this method work on dell e6400 :) ?
  9. moral hazard
  10. gasolina
    gasolina Newbie
    just open up my e6400 =_= and do stuff still can't do anything , my keyboard now is dead with few buttons.....
    any way :) t/y moral hazard :)
