PLL Pinmod Overclocking Methods and Examples
Discussion in 'Hardware Components and Aftermarket Upgrades' started by moral hazard, Jun 24, 2009.
  1. Bunneh
    Bunneh Notebook Enthusiast
    hey, thanks for the quick reply, and also sorry for frying the page layout with
    my huge picture!
    One question: It was my understanding that the bottom right pin in my picture) was pin 17 -
    considering that the pin modded in this is supposed to be pin 64 (FS_B):
    http://img180.imageshack.us/img180/1434/img1966h.jpg
    it also has a tiny nr 17 besides it in both picutures :)
    - Doesn't that pin go directly into resistor R164?
    If yes, can I lift left the leg of the transistor facing away from the PLL and attach it to any GND?
  2. Bunneh
    -double post-
  3. moral hazard
    Yes you're right, sorry.
    That should work.
  4. niffcreature
    niffcreature ex computer dyke
    Hey, everyone.
    All this PLL stuff is great, but I was wondering... could there be a simpler way to overclock 800mhz FSB cpus in a chipset that already supports 1066mhz FSB? I guess TME unlock would be necessary. but otherwise, I have this ES t9300 in my m860tu, why cant I just trick my system somehow into running at 1066mhz?
    It seems like this in particular could be so much simpler... but as soon as I start thinking of other ways to do it there are just so many possibilities.
  5. User Retired 2
    Intel chipset get locked to x6 multiplier if apply a BSEL pinmod to a stock CPU. Your ES CPU might be different. Worth hardwiring your ES CPU for a 1066Mhz BSEL and finding out. If no go, then consider a FSLx mod + slowed RAM timings to get 1066Mhz out of it.
  6. timohour
    timohour Notebook Consultant
    My new motherboard for my fs U9200 arrived. (I 've destroyed my PLL last time)
    I hardwire pll my T8100 and....
    2.8 to 3.06 (at x11,5).:D
    3dmark06 results for cpu from 1765 to 2311 (without RMclock)
    Many thanks to every one in this forum for helping me to get here...
    CPU-Z Validator 3.1.
    Only problem, I had to change my memories (2*2gb @667) because X3100 with mem at 887MHz driver kept rebooting.
    I now have 1*2GB and 1*1GB@533 4-4-4-12 running at 709MHz
    Anyway to solve this?:confused: ( I want to work at 887MHz)
    Thanks a lot.
  7. moral hazard
    Try using thaiphoon burner or SPDtool to change the ram timings so that it will be stable.
    Maybe try running your 667mhz ram @ 533mhz with the stock timings (667mhz timings).
  8. timohour
    I just downloaded spdtool but I cant change anything.
    I make the changes and it gives me errors.
    Do you think there is a way that my x3100 will compromise at 887MHz?
    Is this some kind of driver issue. Because every time I ran at 887 when I stress the graphics my driver reboots.
    I ran osx 10.6.4 mainly, but I just switched to w7 to make sure everything runs ok. I never tested it on os x yet
  9. User Retired 2
    I find x3100 graphics is more overclock tolerant if I set "Rapid Memory Power Manager" and Maximum Battery in the Intel control panel.
    Otherwise the advice to slow down RAM timings is a good one. X3100 uses the system RAM as vram.
  10. moral hazard
    Write protection is probably enabled. Can't flash the EEPROM in that case.
