PLL Pinmod Overclocking Methods and Examples
Discussion in 'Hardware Components and Aftermarket Upgrades' started by moral hazard, Jun 24, 2009.
  1. kaltmond
    kaltmond Clepple
    Even in xp 32bit you cannot run SPDtool or Thaiphoon? In vista X64 is understandable, but in xp......
  2. moral hazard
    yep in xp. I can run them but they can't find any memory modules.
  3. sean473
    sean473 Notebook Prophet
    Any help in overclocking a dv5t with a T9400? I've got no luck finding the PLL for it and just don't know how to do it. Help!!! A guide would be great.
    Thanks.
  4. moral hazard
    If you post some pics of your motherboard we can help ID the chip.
    It's usually (but not always) near a crystal that says 14.318MHz.
    I guess the most common brand would be ICS.
    Another way to do it is by trial and error;
    download setfsb.
    select the first PLL (clock generator) and press getfsb and setfsb and see what happens, then if it doesn't work try the next PLL. Keep doing this until one works or until you run out of PLLs to choose.
    If setfsb doesn't work try clockgen.
    Please post any results.
  5. User Retired 2
    Software to detect *some* PLLs
    SiSoftware's Sandra diagnostic software can detect some PLLs. See more info here.
  6. sean473
    How do you use si sandra to detect PLL?
  7. hustheman
    hustheman Notebook Evangelist
    sean you shouldnt spend so much time trying to OC ur CPU, its not worth it as its not the bottleneck of your system its the 9600m gt. Even if you did manage to OC ur CPU the performance gains would be minor in most games as most of them are GPU dependent
  8. moral hazard
    @sean473, click on the hardware tab then click on "mainboard".
    scroll down to "system clock generator" then look if "read back support" is "yes".
    I believe if "read back support" is yes then it has detected your PLL.
    I have tried it on my laptop and "read back support" is no.
  9. sean473
    i can't find this after clicking what u said.
  10. moral hazard
    My guess would be that si sandra can not detect your PLL, have you tried the "trial and error" method with setfsb?
