PLL Pinmod Overclocking Methods and Examples
Discussion in 'Hardware Components and Aftermarket Upgrades' started by moral hazard, Jun 24, 2009.
  1. moral hazard
    Ok, so now here is what I have done to test if overclocking is possible:
    I used setfsb to increase the fsb a little, and I took a picture of my screen with a camera since setfsb causes my laptop to freeze.
    After the laptop restarted I then manually copied the register values that I saw in my camera to setfsb, except I did not change the source for the SATA clock.
    So bit 1 of byte 0 is 0.
    Then when I pressed apply it worked without freezing my notebook.
    here are the screenshots:
    http://i896.photobucket.com/albums/ac167/moral_HaZaRd/overclocked/overclock2j.jpg
  2. moral hazard
    ok I have new photos attached.
    2.3ghz.
    Edit:as you can see wprime is now 38.031s
  3. tavara
    tavara Notebook Consultant
    How to decrease RAM frequency from 800Mhz to 667Mhz to make a room for higher overclock? or ather option to help me rising FSB.
    Sorry for my bed english
  4. moral hazard
    This would be done using spdtool or Thaiphoon Burner.
    Edit: another option is to buy 1066mhz ram. The ram would downclock in your laptop to 667mhz. Then after the overclock the 1066mhz ram will be running at 800mhz and should be stable.
  5. tavara
    Buying 1066mhz ddr2 ram , is not a option for me because I'm in Europe, and only place where I've seen 1066mhz ddr2 ram is on www.tigerdirect.com and they don't deliver outside US. My lappy is on montevina platform so 800mhz is by default. I'm not familiar with spdtool.How to use it to make my 800mhz to run at 667mhz? :confused:
  6. moral hazard
  7. kaltmond
    kaltmond Clepple
    I've done many times hot flash RAM if they are broken because of flash unproper timings. And moral which system do you use now?
  8. moral hazard
    @ kaltmond, The same toshiba tecra A9 as I started this thread with. BTW thanks for the help with the OC.
  9. kaltmond
    kaltmond Clepple
    I meam windows system, X64?
  10. moral hazard
    I dual boot vista business 64-bit with xp pro.
